Results 1 to 13 of 13
    Reputation: GR1822's Avatar
    What tools for crank/BB removal: 2012 Camber 29er
    I think I'm ready to start doing more of my own maintenance, and have run into a few neewb questions.
    I have a '12 Camber 29er, and the spec sheets say it has the following components
    Cranks: Shimano Hollowtech Octalink spline replaceable rings
    BB: Shimano Octalink spline cartridge bearing
    Ive been watching videos on Youtube for the past hour, and I don't think I'm any closer to knowing what tools I need to pull my cranks and BB and give them a cleaning/lube.
    I know alot of you do ALL of your own maintenance, and that sometimes Specailized has unique components; any help would be appreciated.
    You need an Octalink crank puller to remove the cranks. You use this tool after unscrewing the hex bolt on the crank arm. Park Tool, among others, makes this tool.
    Your crank may use a self-extracting system, such that unscrewing the hex bolt also pulls the arm from the BB spline. You can determine this pretty easily by unscrewing the bolt. If the bolt comes out, and the crank arm is still stuck on the BB spline, you need the crank puller.
    To remove the bottom bracket, you need a tool with teeth that mesh with the 8 notches on the BB. Like this.
    Park's site isn't working for me at the moment, but this guide will be handy when their site is up again: http://www.parktool.com/blog/repair-...ve-or-octalink
    All that said, there's not much to do after removing the crank and BB, other than clean and re-grease the BB splines and threads. Bottom brackets have become throw-away parts, which you replace when the bearings are shot. For this reason, I don't bother to remove my cranks and BB unless something is creaking, or if the BB needs to be replaced.
    Thanks for the info. Park tool's website isn't working for me either. I'll try removing the cranks tonight and see if I need the crank puller or not.
    Well, I finally got around to working on my cranks and I got the wrong BB tool. The BBT-18 isn't the right one. I count 20 'female' notches on the BB, so I think this is what I need Park Tool Co. » BBT-22 : Bottom Bracket Tool : Bottom Bracket.
    Pictures to help confirm:
    What tools for crank/BB removal: 2012 Camber 29er-20130614_201727.jpg
    With the Park tool BBT-18 on if that means anything
    What tools for crank/BB removal: 2012 Camber 29er-20130614_201750.jpg
    Can anyone agree or disagree before I buy the BBT-22 from Park?
    P.S.
    I have a never been used Park tool BBT-18 for sale. Real Cheap!
    old fart
    Correct.
    Purulento
    On a side note, looks like one of the housings is rubbing on the bottom bracket shell. You might consider putting some frame protection there...
    Quote Originally Posted by Purulento View Post
    Where do you see that?
    Purulento
    On the first picture you posted, I'm seeing 3 cable housings. It looks like the upper one is touching the frame.
    I see what you mean. I'll take a look when I get home and report back. It's all factory install, so I'd like to think there is something there...
    Took a look, and there is one of those clear sticker thing-a-ma-do's right there to protect the paint/frame.
    Good eye!
    Reputation: Biking Brazilian's Avatar
    We the people ...
    Quote Originally Posted by GR1822 View Post
    Good eye!
    Even with the BB protector, that FD cable housing is too close to the BB (I assume your suspension is not compressed in that photo).
    Here is a hangtag Specialized now ships with FSR bikes. The shop should've setup this up correctly, regardless of whether it came from the factory that way or not. A bike ships in a box and requires a lot of setup before you even see it on the floor; checking this clearance, among other things, should be part of their setup protocol. That is, unless you've swapped the FD housing since you bought it.
    What tools for crank/BB removal: 2012 Camber 29er-fsr-cable.jpg
    Thanks for the info!
    I'll have to see if I can slack it up a bit. 40 mm isn't too much.
    I have the recommend 40mm now, and boy it seems like a lot.
    the 3 cables are almost even with the bottom of my bash guard.
    But if that is what Specialized wants, that's what I'll do.
    Thanks for the input everyone.
  1. Crank Removal on 2012 Flash 29er Carbon.
    By Flying_Scotsman in forum Cannondale
    Last Post: 07-30-2012, 03:36 PM
  2. 2012 Camber Carbon Pro 29er
    By Spinning Lizard in forum Specialized
    Last Post: 07-03-2012, 12:32 PM
  3. 2012 Specialized Camber 29er
    By wasfast in forum 29er Bikes
    Last Post: 03-22-2012, 06:08 PM
  4. 2011 Camber rear vs 2012 (29er)
    By twenty6black in forum Specialized
    Last Post: 12-02-2011, 06:57 AM
  5. Any word on a new 2012 Camber 29er?
    By subspd in forum Specialized
    Last Post: 05-18-2011, 04:34 AM
