Results 1 to 11 of 11
    What size carve do i get?
    i've read nearly every thread on people asking what size frames they should get in relation to their height, but i still don't know if i should get a medium or a large frame.
    i'm 5' 11". 33" inseam.....i've test drove the medium and the large, i feel a tad stretched on the large, and the medium feels a tad short.
    Which one feels the closest? Then can that bike be adjusted/fitted to fit just right?
    Did u just ride around the parking lot or on trails? Trail time on each would prob be the best indicator.
    Reputation: mudhen's Avatar
    I'm 5' 10" and the medium felt a bit small to me too.
    I went with the large on the Carve Comp, and I like it very much after putting 300 miles on it.
    But, I'm careful, it's a close fit, if you know what I mean!
    If I had the $$$, I'd have a medium & a large....
    mudhen
    "Lighten up Francis" Sgt. Hulka
    I know I struggled with this a lot on my bikes.
    Well I would imagine the stem on the Large is already short. You could move the seat forward to close the gap but that will change your pedaling position.
    Maybe a medium with a longer stem would be better.
    Medium with a longer stem or a large with a shorter stem. Without the stem change actually being done, ill never know which one ill need until I actually buy the bike and the stem change is made. It's hard to tell from a 5 min. Test ride in a concrete parking lot.
    Trail Rider
    I'm 5'10.5" and have a 30" inseam, medium frame with a 90mm stem fits like a glove.
    well the bike shop should be able to fit you, they have stems there...though fitting usually costs something.
    '12 Scott Spark 29 Team
    '13 Scott Scale 970
    '11 Scott Speedster S20
    '99 Spec' FSR Comp
    '9x Spec' Hardrock Cromo rigid
    nothing to see here
    Reputation: Stevob's Avatar
    get the medium
    I see hills.
    I want to climb them.
    Don't try this at home.
    Reputation: RobbVII's Avatar
    I'm 6ft and I bought a large. But my arms are 38" long so the cockpit had to be a little longer. If I wasn't such a knuckle dragger, I definitely would have went with a medium.
    Reputation: Randall in NC's Avatar
    The stems are a bit short on the Carves, try a medium frame with a 90mm stem. I bet it will fit you great...
    a medium it is!!
