Results 1 to 2 of 2
    Feb 2005
    what to lube pivts / shock mounts with (epic)
    hi this might sound stupid, but does it matter what oil i use to lube my shock mounts / pivots with? Bike has started creaking, so i thought i'l lube them up a bit.
    I've got finish line wet lube and Rock n Roll extreme lube, or just plain old engine oil! Or do i need something fancy?
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    you need grease.... to repack the bearings in the pivots...oil will just attract dirt and create a paste that will cause more wear
    clean and repack
