Results 1 to 5 of 5
    Reputation: subspd's Avatar
    What is the frame only weight on the '11 stumpy FSR 29er?
    Like the title says anyone have a weight in size medium. Would hate to take mine apart to get a baseline number.
    Aug 2010
    6.9 lbs is what I've read.
    The numbers that I got from various sources are the following (including the brain damper, which is something like 440 g separately).
    Epic S-Works: 2350 g approx
    Epic Carbon: 2650 g approx
    Epic M5: 2950 g approx
    Aug 2010
    I was looking into frame weights for some FS 29ers (and a few 26ers) that were of interest to me, and here is what I found.
    Santa Cruz Blur XCc (100mm travel), 4.1 lbs (26er)
    Santa Cruz Tallboy Carbon (100mm), 5.1 lbs
    Niner Jet9 (80mm) 6.3 lbs
    Epic M5 Alum (100mm) 6.3 lbs
    Santa Cruz Tallboy Alum (100mm) 6.64 lbs
    Spec Stumpy FSR 29er (130mm) 6.9 lbs
    Pivot 429 (100mm) 7.1 lbs
    Niner Rip9 (120mm) 7.5 lbs
    So, for the amount of travel it has, the Stumpy FSR stacks up really well, perhaps the lightest aluminum FS 29er bike in the 120-140mm range, but I haven't researched them all.
    Thanks for the breakdown I have had some people ask me what it weighs and I had no idea I know fully setup I'm at 28lbs (tubeless). So for the size of the bike it's not really that bad. All this talk about the tallboy aluminum but with less travel doesn't really stack up. What is an Anthem x FS weigh?
