    What bearings do I need for an overhaul of my '09 SX Trail?
    Anyone happen to know where I could find a list of what bearings I will need to do an overhaul on my 2009 SX Trail? It's currently all torn down and at the sand blaster having it's paint taken off. I think I'm gonna leave it raw but I want to replace all the bearings while it's apart. Some of them do not budge at all.
    Did you get a manual with the bike? There is typically an exploded view showing all the suspension piviot hardward and bearings.
    It doesn't look like there is an '09 manual on the Specialized website. So if you don't have one check to see if your frame is the same design as the '08 frame.
    Otherwise call specialized or measure the bearings in your bike.
    No, I bought it used and definitely didn't get a manual. I believe that the '09 was quite different than the '08.
    old fart
    Go to the website under Service and hunt for the manual. That has an exploded view of the frame wiht the bearing numbers (using industry standard designations so that you can order from any engineering shop).
  1. XTR pedal overhaul
    By rockman in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-14-2016, 02:44 PM
  2. Replies: 11
    Last Post: 09-12-2013, 07:35 AM
  3. Cartridge Bearings versus Cup and Cone Bearings
    By caesar148 in forum Weight Weenies
    Last Post: 01-06-2013, 05:51 PM
  4. Overhaul?
    By circlesuponcircles in forum Ibis
    Last Post: 12-04-2012, 05:48 AM
  5. Overhaul vs New Bike
    By KingCobra in forum All Mountain
    Last Post: 05-24-2011, 06:36 AM
