Results 1 to 3 of 3
    wanted, front QR 9mm axle for Stout hub
    I know you can get them new but I would rather reuse if possible. Thought I would try here first. Thanks
    I think you are looking for a "skraxle". If you do order one make sure you say "Scracxel" so you get one that's half skewer, half axle. Even my LBS that I bought stumpie from ordered the wrong one when I needed the fat thing.
    Dec 2008
    Those things get loose quite often; I used to ride an enduro and it would get loose on long rides.
    Enduro Comp 04 Front Skewer is LOOSE
    I replaced it with a Hadley 9mm axle for $20 or get the dt swiss ratcheting axle that Specialized currently uses.
