Results 1 to 36 of 36
    Reputation: EGF168's Avatar
    Tires for Stumpy
    1-Kenda Nevegal
    2-Conti Vertical pro
    3-Maxis Ignitor
    Which of these tires would you guys buy for a 07 Stumpy comp that currently feels like figure skating of road with worn out stock tires. I will be riding on road, loose, sand and some peaty mud. I know how good the Nevegals are so I was wondering about the other 2.
    Has Conti improved since they brought out the Explorer tire about 7 years ago which I had and it got so many punctures I ended up stabbing them to pieces with a kitchen knife.
    Thanks EGF
    Reputation: tonys102's Avatar
    I run with a Nevegal on the back, with a Blue Groove on the front. That seems to work fine for me in the sand around the north downs. Although I am possibly looking at some Nobby Nics, as I use the Racing Ralphs in the summer and they just fly!!
    Building: ​Boardman 2010 HT Pro
    Current Joy: '11 Giant Anthem X
    Previous Joy: '09 Commencal Meta 5 VIP
    Iíve got that set up on my 08 Trance X2-see trance thread, they seem to work very well together so I may do it on my stumpy too but I still have 2 hours before I ring the dealer to order my new wheels. The Nobby Nic`s are too expensive for me though.
    I see youíre in Guildford and Iím in Slinfold nr Horsham so we ride in the same area which helps.
    Top drawer... For a REALLY good day out we spend a few hours around Leith and Holmbury. The cakes at the top of Leith are awesome, unless I have baked up some myself. However, the last time we were over there, we had a major mechanical miles from our cars!!!!! Do you manage to get over that way at all??
    Reputation: terrible's Avatar
    Started running the specilazed captain tires in 2.0 front and rear. There great for wet leaves and running water on trails.
    The Other Dude
    Reputation: jut8's Avatar
    I agree, the new Captain's are are killer tires, they hook up in wet conditions, and roll super fast, i will be running them on my 08 stumpy.
    Sponsors: Specialized, Honey Stinger, The Hive, Twenty6, 661, Elka Suspension, www.Chainsmokeracing.net
    Just Wanna Ride!
    I'm running a Resolution 2.3 front and a Captain rear (29er) and love the combo. Suprised at how good the Captain is. Fast rolling, good cornering grip, very predictable all-round handling. It's already a great tire, but if they made a larger casing option for the Captain it would be awesome!
    I'd be sure to put the Captains on the short list!
    Not sure if they are available this side of the pond... They don't seem to be listed on the UK specialized website...
    Iím willing to have another look at the Spesh Captain tires but the last time I tried them was in about 2in of very fine dust, I tested them on an 08 Stumpy back to back with a hard tail Marin that had WTB Prowler tires. The spesh tires simply didnít hold a line and they drifted everywhere where as the WTB tires which I have also tested without the dust where perfect and would be my 1st choice but I cant get any round here.
    Allot of people I know are saying the Maxxis Ignitor tires are perfect generally apart from tread life which isnít really a problem for me. I know allot of people use Conti Vertical on the South Downs which is very chalky. And I can see that my Nevegals slow very noticeably if they are on soft mud-not to be confused with wet kind of mud.
    tonys102
    I do allot of riding on the north downs near Leith hill, Peaslake and Dorking, I have also done a few rides on the south downs mainly between Worthing and Lewes. Iím usually seen on Leith hill on Sat or Sun eating the delicious cakes around 10.30 half way into my ride.
    Mar 2006
    As far as tread pattern goes, the verticals and the ignitors are virtually identical.
    Reputation: emeterio's Avatar
    what about panaracer XC tires 127 tpi???
    No dudes, no temas, no te arrepientas.
    They are very similar tires but with the Conti Explorerís performance, which is also very similar I think Iíll be getting allot of punctures, my best was 1 punctures every 2 rides on them. There was a major performance increase when I put some WTB Velociraptors on my old Whyte PRST-1, no punctures anymore. Donít think I want the Conti tires + they are Conti which I donít like as much as the other 2 tires Iím choosing from.
    Has no one got the Ignitors on here? I have looked on the tire and wheel forum and found a few people that like them.
    Only got £50 total and those are £55, when I tried them they were slow and ugly-personal opinion.
    Mar 2006
    I'm running the Ignitor in the front on my stumpy, the 2.3 ust version. Worked fine for me all during the dry summer. Doesn't slip out unless you want it to. Not notably fast. Just starting to rain here in Northern California, so I can't comment on its wet performance.
    I'm about 190lbs. with gear, and have to run it at 35 psi to prevent rim dings. I ran it at 30 for a while and was getting rock on metal with moderate trail riding ( this is a front tire mind you).
    Also, after about 6 months there are weird bulges appearing on the sidewall near the bead. I'm running Stans, which may have something to do with that.
    Quote Originally Posted by EGF168
    tonys102
    May well catch you at some point... check out www.rancid-cat.co.uk...
    I went with Maxxis Ignitor 2.35 (2.2 if measured). I went for those because I havenít had them before-something new to try, also because they were about the right size-only slightly bigger than 2.10 and quite a few people recommended them. Cost me £24.50 each EX 10% of from dealer.
    Iíll put them when I get my next puncture which should be any ride now.
    Be interested to know how you get on with those over the north downs!
    Apparently theyíre a bit faster and last allot longer than the Stick-E compound Nevegal and they last a lot longer than other Maxxis tires like High Roller which last for according to the dealer about 120 hrs riding which is pretty rubbish, even more shocking is Iím fairly sure heís telling the truth.
    The people I asked seem to think they last about the same as normal compound Nevegals, they also thought the Ignitors were very surprising on the north Downs.
    Yep! The tires are fantastic, I’m running them at 40psi, I’m going to compare them to 2 other tires, the Specialized Resolution Pro 2.00 and the Kenda Nevegal 2.10.
    With all 3 of these tires at 40psi the Neves are slower but you get better grip and they don’t vibrate as much as the Ignitors, the Resolutions are the Smoothest and the definatly have better tread life than the Neves which I can already see wear on after only a few rides. The Ignitors seem to have a fairly hard tread which makes for a good tread life but I haven’t had them long enough to see, they roll and accelerate very well and although I thought the Resolutions roll well and are quite fast these are definitely allot better, another good thing is that although they are 2.35 tires they have left about 10mm more tire clearance on the rear of my Stumpy than my supposedly smaller Resolution 2.00 tires, the traction is much better than the Resolutions which is one of the reasons I wanted new tires but the traction isn’t quite on the level of the Neves. One small complaint about the Ignitors is the ludicrous amount of vibration from the far apart tread, but that doesn’t really matter cos I ride fast enough to smooth this out. Both the Neves and the Ignitors have much better puncture resistance than the Resolution pros.
    I would be happy to recommend the Ignitors as they are perfect for me. I have tested them on all surfaces such as clay mud, sand, peaty mud, sandstone, chalk and a little road riding. In all conditions except bone dry.
    Hope this makes sense + here are the tires when new on my bike.
    Have you managed to get out in South Downs clay/mud recently. Would be interested to know what these are like, as my Nev's let me down badly at the weekend round Cheesefoot Head...
    Where’s Cheesefoot head?
    Anyway, no these tires are not particularly grippy in clay mud but are much better in other mud’s, but I think they make up for the lack of mud grip with much less mud actually sticking to the tires, I use to have to dig the rear wheel away from the frame with my old Resolutions which may be caused because they were such a big balloon tire.
    Obviously I’m not using mine for purpose as both the Nevs and Ignitors are not really for mud.
    I would say they are allot more grippy on the south Downs way chalk than other tires I have tried up there.
    Just outside Winchester on the South Downs Way!! I was really struggling for grip with mine, although I think that may be because they are over a year old...
    Never been there, I usually do west of Worthing to about Lewis but rarely in one go. I have never lost grip with my Nevs or the Blue Groove at the front but when I goes over not dry mud but kind of soft you can really feel the bike slowing.
    If I had the money I would get some winter tires and some summer tires, perhaps even a second wheel set to whip on and of for different conditions, but I have gone a little over budget with 2 new bikes this year.
    How much tread do you heve left?
    The back is pretty worn down on the centre, the front seems ok, but they just got clogged really quickly, that it was like riding a couple of slicks!!!!
    I havenít ever looked for a mud tire but the 2.35 Ignitors have quite a far apart tread patter that stops it from clogging up as much as other tires like my Resolutions I mentioned earlier, also the Ignitors have a very low profile for a 2.35 which gives extra clearance. The Resolutions ended up like slicks in the end, I think it was the day when I ended up in a stream that tipped me of I needed a new tire.
    I usually try to keep away from heavy clay in winter, the north downs with the soft non sticky mud is really good.
    Nevs seem to wear down quite fast, at least they arenít as bad as Maxxis High rollers.
    Which compound are you running? because one of the compounds is designed to stick to the ground for grip and the other is just standard longer life tread so it may explain why you clogged up so bad if you was using the Stick-E compound and not the standard DTC
    I think I am running the DTC at the mo, but they have seen some miles.
    I havenít taken my Trance X out this week other wise I could be more helpful about the tires, mine has Nevegal DTC rear and Blue Groove Stick-E on the front, both 2.10. Iíve been out on the Stumpy these few weeks, even thought I had the TX up Leith hill for Student Driver on here.
    I see you have a carbon Stumpy so Iím going to ask the obvious and unrelated question seeing as how you live in Guildford, Beyond mountain bikes or Cycleworks?
    Jackie at Beyond. They do most of the 'heavy' work, whereas I do a lot of the day-to-day stuff.
    Jackieís quite good, I nearly bought an 08 Trek Fuel EX8 from her but I got the Trance X because I got such a good deal. Iím trying to find a really good bike shop to do my work, I havenít really tried Beyond much so I donít know about them, Nirvana nr Dorking is very good and where I got the TX from. Head for the hills in Dorking is very interesting but the mechanics arenít very good.
    I see they are now selling Scott bikes, if you are interested they have a very nice top of the range Scott Genius in with full 08 XT in nice carbon.
    Nov 2006
    nevegals for any mud conditions is my vote, but when it drys up a little the spesh fastraks due a good job that come with the bike.
    They are good guys there and seem to know their stuff. I had a dodgy 'brain' on my shock which they were more than helpful in sorting out...
    Reputation: Lipps64's Avatar
    Cool-blue Rhythm Everyone has their own preference, but for me......
    Certainly The South Downs and Downs Link are thorn-ridden and sharp flint & chalk prominent; underfoot conditions which beat up even the most expensive specification of tyres
    Similarly, these routes have broadly differing traction conditions every five miles or so, therefore there is bound to be a trade-off or compromise with tyre choice; it's just not possible to select a tyre that will do it all seamlessly
    Myself, for general fast & grippy trail riding on these routes (of which I am a regular [as well as The North Downs]) I go for the cheapest version of Continental Speed Kings 2.3 (ie, the wire-beaded/un-folding/un-packaged [only around £11.50 each in the UK and in my experience, have lasted pretty well as long as many of the high-end £35.00+ tyres that I have used for these tyre-harsh environments). I couple these with Slime tyre liner tape (to cope with the thorns) and generally run @ 50 psi pressures unless I hit on prolonged sections of the notoriously slippy wet chalk found on The Downs and want a bit more grip; in which case, I would reduce the pressures slightly;
    No, these are by far not the best tyres in the world; but when used with the Slime tyre liners, certainly do the job pretty well and as ANY manufacturer's tyres used on the routes mentioned WILL become damaged & degraded at an accelerated rate, then certainly this has proven to be an extremely cost-efficient all-round tyre option
    By the way; Slime tyre liners (which really do cope well with Downs' thorns) are only provided in widths normally suitable for 2.1 tyres maximum. However, Continental's entire range of mtb tyres come up significantly slimmer than other manufacturer's of the same size-rating; therefore, Slime tyre liners are fine for use with Continental 2.3's
    Cheers for that... I think the problem I have is that the Nev's and Blue Groove's don't have enough spacing for shedding that gloop, hence I ended up with a couple of iced donuts for tyres... Not good
    Cool-blue Rhythm Could be a "Downs' Mud" thing?
    Tony
    Not wishing to sound like Network Rail with their, "Wrong kind of snow" type excuses; but I do have to say that the particular mud akin to The Downs around yours & mine neck of the woods is exceptionally difficult to target an ideal tyre choice at
    The problem seems to be not during heavy rainfall, when the mud becomes somewhat more emulsified in absobed water (ie, runnier & less adhesive); it is that next 12 hours or so, that the mud is relinquishing much of the rainfall.........It really does become thick, highly cohesive "Gloop", that would require a stick to free the tread of any tyre irrespective of pattern or tread depth. This stuff is capable of standing your bike up unassisted at only a couple of inches depth with no problem; you need thighs like a Rhino to be able pedal through it and possess the ice skating skills of Torvill & Dean......
    To add to the problem; the Downs are interspersed with so many entirely differing underfoot terrains every five miles or so; therefore to go with a true "mud tyre" would not be the answer for day's riding
    What's the answer then?................contribute towards an accelerated increase Global Warming!?!!!
    Quote Originally Posted by Lipps64
    Tony
    Yes, that is the same conclusion that I came to...
    Well I have now done it, started in Winchester and a few hours later arrived to be picked up in Amberley, I did it 3 weeks ago a couple of days after the heavy rain, the Trance X (I know itís the wrong forum but itís my thread) with a 2.1 Nevegal on the back and a 2.1 Blue grove on the front was completely useless, I have never been so depressed with a bike.
    My experience was probably even worse than yours Tony, the conditions were appalling, the tires had no grip, the tires clogged up pretty much immediately, the worst part was when I looked down at the rear end of the TX and realized just how bad the tire clearance is on this bike, I literally had to get of the bike and dig the rear wheel away from the frame, this is something I was not expecting as the Stumpy and my other bikes have managed to pull through heavy clay mud like this many times even with the back wheel completely clogged up, they always pull through but the TX just stopped completely, I couldnít even pedal in first gear. My friend on a HT Stumpy was having much better luck, he had Panaracer Trailracker 1.9 tires on and the were very good in the mud.
    Anyhow, have you changed the tires on your Stumpy yet?
