Results 1 to 3 of 3
Thread: Tire Selection
    Reputation: FlowMaster23's Avatar
    Mar 2013
    Tire Selection
    I am looking to buy new tires for my stumpjumper HT 29. i will probably buy the captains. should i go 2.2 or 2.0 or 2-front 0-back. and which type should i go. i think the armadillo elites will be good, or should i go s-works or control. my friends go 2.2 s-works on the front and 2.0 control on the back. and another i know run 2.2 elites, and the other runs 2.0 elites.
    Skip the Armadillo unless you're dealing with a lot of sharp rocks on your trails. I would suggest the Control over the S-works. The Control is cheaper and will last longer, and the weight penalty is relatively insignificant.
    Go 2.2 on the front for the added traction. On the back, the width isn't as essential, but the added volume of the 2.2 will be a little more comfortable than the 2.0, considering you're riding a hardtail. Decide whether the slight improvement in acceleration with the lighter 2.0 is worth the sacrifice in shock absorption offered by the higher volume 2.2. I run Fast Trak Control 2.2 front and rear on my rigid SS for this reason.
    Depending on your trail conditions, it's worth considering a faster rolling tire like the Fast Trak in the rear, or even in the front, too. I won't make that recommendation without knowing what kind of trails you ride, though.
    Mar 2013
    well, many people i know run the captains, and we all ride the same areas, so im guessing they will be good tires. im thinking 2.2 front and 2.0 back, and both elites, the guy at the bike shop reccomended them because we both big riders, him being a bit over 200, and me being 240. ima go w/ that setup, or both 2.2. thanks for the help
  1. Tire weight vs tread pattern. Tire selection help
    By Bones2 in forum Wheels and Tires
    Last Post: 10-18-2012, 09:35 PM
  2. RDO Tire selection help
    By tws_andrew in forum Niner Bikes
    Last Post: 03-14-2012, 10:55 AM
  3. help with tire selection for a particular course
    By tetonrider2 in forum Endurance XC Racing
    Last Post: 08-12-2011, 04:16 AM
  4. Tire Selection
    By wog131 in forum New York - New Jersey
    Last Post: 06-14-2011, 08:53 PM
  5. Need help with tire selection
    By theGreenEGg in forum Commuting
    Last Post: 05-16-2011, 12:10 PM
