Results 1 to 28 of 28
Thread: SWorks tires
    SWorks tires
    So the wife bought me a set of SWorks tires for me. Mount them up tubeless and find the front Purgatory has a pin hole in the sidewall out of the packaging.
    I normally can be pretty anal about stuff, so my question is, do I let it roll since it seems like the sealant is holding so far, or do I return it? It is a $60 tire.
    OG Ripley v2
    Carver 420 TI
    Reputation: HAL 9000's Avatar
    If it's holding air with sealant don't get stressed
    Pin hole in sidewall, Ok...if just between the thread and the hole is in the rubber, but I found a tire like that also to be out of round side to side, had to take it back a few days later, also had a flat first time out, no longer use any Specialized tires, bad quality, better tirers out their.
    I've been riding Specialized tires for years without issue. Good bang for their buck and with various compounds.
    MCH Co-Captain
    West Chester, PA
    Only 1 spot where sealant is weeping ? That doesn't seem right, they should be weeping much more than that.
    Dec 2010
    S-works tires,they are very light and fast but that comes at the price of much thinner sidewalls, hence only use for racing and even then, depending on which tire you are using and length/condition of race course still might be better with going the the control (thicker sidewalls) version of the same tire; for training or just riding, no brainer, always get the control version of the same tire; if I were you I would take back the s-works and get a control version, unless you are going to be racing on that tire, otherwise depending on the type of riding you are doing, the s-works will not hold up for as long, my two cents from someone who has used spec. tires for a while now (fast track 2.0 in front & renegade 1.95 in back)
    West Chester, PA
    Yup, if they'll let you swap them for control versions it's worth the extra ounce or 2 per tire. Even then, they may not last that long if you live in an area with sharp rocks.
    Thanks for the opinions, I've used Spec Sworks tires for a long time now, I'm just new to tubeless.
    I actually decided to run it past them and let them decide. It's holding air now, but I'd hate to go for the first ride and it become something more. Right now they can see it's never been ridden. This way I cover myself before my first ride on them tomorrow.
    OG Ripley v2
    Carver 420 TI
    gunslinger
    Reputation: selector's Avatar
    Pinhole? I'd return it and not even think twice.
    As for running Control vs S-Works, I only run S-Works and I beat the hell out of 'em. I cut a sidewall for the first time only a few weeks back, and that tire (rear) had a lot of miles on it.
    Dec 2010
    You're right to be cautious and return it for another one if you plan to ride tubeless, which is all I ever ride now. While it's only a pinhole, not one of the S Works tires I ever bought leaked at all over the past 3 years when new. Any leak on the sidewall would be harder for the sealants to seal permanently.
    It really does depend on your terrain. I finally tossed in the towel and went to heavier tires with sidewall protection after going through 5 tires with sidewall nicks that the sealant couldn't seal. Had to throw tube in till tire wore out. Slow learner, eh?
    If you don't have a lot of rocks the S Works tires might last if you ride carefully. Of course that's what I always told myself until the final blow. A rock hidden in tall grass caught a side knob, flipped up and put the smallest, barely visible nick in the sidewall. Wouldn't stay sealed with Stan's. So the "I'll ride real careful" thing only goes so far.
    Even if a sidewall leak does seal, how are you going to trust it 100% on the fastest, gnarliest descents? That's the other reason I threw in the towel.
    IMHO you are making a mountain out of a molehill
    kenda tires are legendary for having weepy sidewalls when using stans latex the simple solution was to place the wheel over an open box and let the sealant plug up and sidewall leaks.
    yes the S Works tires are light and made for "racing" more or less if you want better sidewall protection get the Control edition of the tire you make be giving up a few grams however the side wall protection is worth it.
    Quote Originally Posted by HAL 9000 View Post
    Well maybe I shouldn't of said pin hole, this isn't weeping, when it's pumped up to 55 psi to seat the bead it's a very loud fast leak, not a slow weep
    OG Ripley v2
    Carver 420 TI
    Regarding S-Works tires, it's not just how rocky your area trails are, it's how sharp the rocks are. Where I live in western Washington, I use S-Works tires year-round and they are fantastic. If I ride in eastern Washington, S-Works tires are a no-go because the rocks are very sharp. I prefer S-Works tires because I feel like the ride is a little more supple due to the thinner sidewalls.
    As far as sidewall cuts, since a mountain bike tire is used with low pressure, you can actually patch a sidewall cut. I've only had one cut in an S-Works tire in many, many hours of use. I was able to ride home with the Stan's slowing the leak a little, and me stopping to pump the tire up a few times. I removed the goop, cleaned the tire with acetone, patched the tire and used it until it wore out. Bear in mind, it was a small cut, and I used the tire on the rear wheel.
    PS It's not well publicized, but Specialized has a no questions asked 90 day warranty on all tires. You use it, you don't like it, you return it and get your money back.
    TOM
    USA Cycling Certified Coach
    www.tomsbicycleblog.blogspot.com
    2014 SW Epic WC
    2012 SW Epic
    2014 SW Tarmac SL4
    I like turtles
    Reputation: TiGeo's Avatar
    My newest batch of Specy tires have some small "pinholes" in the sidewall that show sealant. If it is holding air, don't worry about it. The S-Works tires are supposed to have thinner sidewalls to save weight.
    Geologist by trade...bicycle mechanic (former) by the grace of God!
    2018 Niner RKT 9 RDO - enduro are #@$%
    gunslinger
    In the interest of full disclosure, I cut a sidewall yesterday! It was a PIA just cuz it happened, who really likes to flat, but it was funny considering only 24 hrs earlier and wrote what I did above.
    No matter, I'm still sticking w/ what works, and S-Works works.
    Quote Originally Posted by selector View Post
    Sure enough, finally went on my first ride yesterday with the new tires and cut the side wall enough it wont seal.
    OG Ripley v2
    Carver 420 TI
    Get them replaced, exchanged...then sell them on ebay, you will loose some cash, but you can take the money and invest in a better tire...Wish some one would of told me not to buy them, nice bike, bad tires...don't let them talk you into a different specialized tire...just a waste of time and money..you will learn the hard way like I did.
    Oct 2012
    My 02, Tubeless? and your banking on sealant on a brand new tire? Not even a debate. No Sale, why take a chance a ride gets FUBAR? IMO it gets returned for something that wont get stressed from a ride or MANY, and become a genuine flat. Thats just me..... Why Wait for the enevitable tragedy.....
    Oct 2012
    Quote Originally Posted by StumpyH View Post
    EDIT: Now that I think about it, our sport is expensive enuff as it is. Why settle for less than Perfect from our manufacturers we patronize????
    Reputation: ghughes.hesinc's Avatar
    Specialized has a satisfaction guarantee on tires (or at least they use to). Just take it back to the dealer. They should swap it out!
    Quote Originally Posted by pedaldown View Post
    Damm good tires actually. The tread pattern is great. I'll just go back to the non SWorks ones.
    OG Ripley v2
    Carver 420 TI
    S Works tires are iffy for tubeless use except in pretty tame conditions. Control versions are a much better bet. If you're not gunning for world cup podiums and/or a paycheck, I'd go that route and save yourself some frustration and walking.
    But regardless, you should never be trying to put 55 psi into an mtb tubeless tire!
    Whining is not a strategy.
    Return them. Specialized tends to have a pretty liberal return policy on their tires...
    like kosmo said... get the control version. they are heavier but the casing is designed for improved cut resistance
    Quote Originally Posted by tednugent View Post
    Already called Specialized and even told him I hit a rock and torn the sidewall. He said it's covered under the 90 day satisfaction. As much as people bash Specialized, anyone know of another tire company that does that?
    OG Ripley v2
    Carver 420 TI
    Quote Originally Posted by TwoTone View Post
    Specialized has always treated me great!
    Not to bash Specialized tires, because of the Big S name, really itís to help a manufacture to come up with a better product. Itís a form of input and feedback, what works and what doesnít. The Big S has a great tire warranty and helps find a tire tread pattern that works in local terrain all cool; however, when it becomes common place to get a flat, or torn tire on the first few rides, the warranty does not help out walking the bike back to the trail head, or mosquitoes fixing a flat or trying to perform your best on a race day. You had mentioned a pinhole, the Big S could do a better job in Quality Control, have them sort out the bad tires and not the rider. If youíre happy knowing you can get a free tire replacement great, but eventually the 90 day warranty is up and you will be at the same place you started, looking for a different tire and the lbs might not be looking at you so friendly each additional time back to the store. Let us know how it works out for you when the 90 day warranty is up, would be interested to hear how the tires held up.
    I like turtles
    S-works tires work great; I have had 2 different ones set up tubeless with no issues. Look, if you are using these tires in rocky areas obviously, you are more likely to get flats. They are "racing" tires. My buddy has torn his Racing Ralph twice, its b/c those tires have thin sidewalls for racing.
    Funny thing...Racing Ralph is what I replaced the Specialized tires with and have held up great, never torn a Racing Ralph, occasionally I here that pinch sound between the rim and tire, no problem, I try not to be to specific with what tire I replaced the Specialized tires with, but you hit the nose right on the button.
