Results 1 to 2 of 2
    Jan 2013
    SWAT Box - Need a thin 29" tube with a long presto valve
    Hey All,
    I need tube help for a SWAT box I'm running on my Epic World Cup. When I use a standard Specialized tube it's too thick and has to be jammed into the SWAT box to fit. Specialized recommends a Turbo tube, which is a lot thinner. Problem is it only comes with a 32mm valve. I'm running Enve XC wheels and the 32 isn't long enough. Also, the Turbo doesn't have a removable stem to put an extender on.
    Any other brands make a thin 29" tube
    Just get a tread on extender what give over the stem. Once you get home your gonna pull that tube back out anyhow. Since I am not running a dropper seat post I went with a saddle bag and am using to standard Ti King bottle cages on a med frame. Just a thought.
  1. Tube tear at valve stem
    By KenInCa in forum Wheels and Tires
    Last Post: 03-31-2014, 11:39 AM
  2. Replies: 5
    Last Post: 04-12-2013, 06:21 PM
  3. Replies: 11
    Last Post: 12-20-2012, 01:13 PM
  4. Grips "T.H.E. G-4 THIN LINE LOCK ON GRIP"
    By jstone8158 in forum All Mountain
    Last Post: 10-05-2012, 06:47 PM
  5. Long ride in thin air - suggestions wanted
    By Black Bart in forum Arizona
    Last Post: 07-13-2011, 11:46 AM
