Results 1 to 44 of 44
    Swapping the rear shock on a 2009 FSR XC Comp
    I had a search on the archives but couldn't see much but has anyone done the above? I'm aware of the propietary shock length (190mm x 45mm)
    Who has done it and what did you swap it for? Did you get the shock customised to the correct stroke? I've seen some great deals on 190mm x 50mm shocks and I'm wondering if I'd get away with that without having to alter the stroke length???
    Any advice appreciated.
    Reputation: bgfthntr's Avatar
    Bob, this seems to be a common question. I've posted this as well. Looks as if some are using the 2" stroke with no issues. My concern is bottoming out the rockers. You can can a RP23 shimmed from PUSH. Personally I'm not taking the risk because I've bottomed my shock a few times and don't want to risk frame damage. See my post below.
    I Hate This Shock... Help!
    also it seems to me if Fox, RS, Manitou etc... could make this size available they would have line at the door for customers. I've checked with them all. X-Fusion has some instock and Fox has the Triad in the Specialized specific sizing.
    best of luck...
    Don't think this will work. advice on stw was
    removing the shock and lowering the bike until the measurement I to I of the 2 shock mounting points is 190-50= 140mm appart. If nothing fouls then there is no reason not to fit the other shock.
    I did that and
    I removed the top bolt on the shock and moved it out the way and fully compressed the suspension until it hit resistance and won't move any further.
    At that point the i2i distance is 145mm so I'm assuming then than the 190mm x 50mm shock would definitely result in the frame hitting itself at some point?
    and
    Distance between the arrows is 145mm
    The point circled in red is where the rear triangle hits the linkage and stops the suspension compressing any more
    The Toasted One
    Reputation: Toasty!'s Avatar
    Here my bike...
    i replaced the stock Xfusion shock with a Fox RP2 7.5x2. No problems at all
    Result!
    Fox Float RP2 - £100 from CRC
    TF Tuned stroke conversion - £40
    Quote Originally Posted by BoardinBob
    Result!
    Where did you get it Bob or going to?
    thx
    Reputation: rufflesurf's Avatar
    did you have to get bushès?
    It came with them
    Bike Addiction
    Reputation: 00sable's Avatar
    Top and bottom bushings? Have you installed yet? Just bought mine and am wondering about bushings and installation. Going to try and install myself.
    Disclaimer: Always get a second opinion cause I'm just guessing
    It's just arrived back from TF after having the stroke reduced. It has one set of bushings that aren't fitted to the eyelet. I'm assuming they're for the bottom eyelet.
    Thinking about the top eyelet on the x-fusion unit, on the bike there's a bearing in the eyelet, two washers either side with a large-ish bolt securing it all together
    Bike Addiction
    Thanks BoardinBob, I was wondering too if I was needing a new reducer. I'm ignorant of this because I have not removed my old shock yet to see whats involved or whats in there. I'm assuming there are reducers. Guess I'll wait till new shock gets here to remove X-Fusion shock from bike. Wanna be able to ride it for now.
    If you look at the exploded views on page 14 here:
    http://cdn.specialized.com/OA_MEDIA/...yka_Manual.pdf
    The bottom eyelet of the shock appears to have the bushings
    The top eyelet has the bearing with the washers either side. It may be that I can reuse the upper bearing and hopefully the bushings will fit too. I'm dropping it into my LBS tonight to get them to do the fitting as I don't have the tools to remove the bearings and if i need new ones they can order them in quickly.
    Bike Addiction
    Thanks again BoardinBob.
    Bike Addiction
    Rp2 shock
    Took my shock off last night just to look at the parts. Got a reply from Fox yesterday and am going to try to order a reducer this morning. Also got in contact with a guy on here mtb4life and ordered a bushing tool and bushings to install the shock. It's going to be a couple of weeks till shock comes in. I think its going to be simple, lbs probably could do it faster. But I want to wrench. May regret it. Ha ha.
    do you think pitch travel plates would fit a xc comp?? lets see some pics of the new shocks guys
    Bike Addiction
    I finally got my rp2 shock in from CRC. It took 3 weeks to get here. I live in the US. They are probably really busy this time of the year. Installed last night and was a little dissappointed with the propedal (soft) but the ride is much better. No more pogo feeling. Can't wait till this weekend to really give it a go. Got a few pics of shock and installation parts from fox if any one wants to see.
    Bike Addiction
    Pics of parts and #'s
    Parts for X-Fusion to Fox swap. Swapped from 7.5 X 1.75 X-Fusion to Rp2 7.5 X 2.00. Already have taken bike off 2 foot drop flat to flat and no bottoming out or frame contact. Just rolled off seated landing on rear wheel. I weigh 170 lbs. It used a lot of the travel but was fine. Well worth the upgrade. About $200 for everything,loctite blue,spacers,reducers,bushings, bearing, shock and tool from mtbiker4life. The tool made things a little easier and faster. Swap easier than I thought.
    Attached Thumbnails Attached Thumbnails Swapping the rear shock on a 2009 FSR XC Comp-dsc00188.jpg
    nice one for the part numbers,time too shop,just don`t tell the mrs
    Bike Addiction
    New shock ride
    Rode the new shock for several hours this weekend and I am impressed again. I climbed some technical stuff and cleared it for the first time on this bike. Climbing really shined and in the saddle climbs too. Rear end stayed glued to the ground. Doesn't bunny hop as easy as it used to but I can live with that. Rp2 is still no rp23 but its close. I still feel rp2 is a little soft in propedal but I think its getting better with the breakin period. Propedal seemed a little stiffer after riding for a couple of hours. I ran more pressure in the 2 (160) than the 23 (140). Still tinkering with it but really impressed.Did I mention I was impressed?
    Interesting that you say your pro-pedal is soft. My shock is in medium tune for rebound and compression and the pro-pedal is very firm. Totally locked out on smooth terrain but kicks in when needed. I'm wondering if shortening the stroke length is the reason mine feels different to yours.
    Bike Addiction
    Mine is med too.The first ride after installation I couldn't tell the difference if PP was on or off. Even off the bike pushing down with arms there was little or no difference. But after riding a few hours last weekend I can feel the difference now. It seems to be much more pronounced when in PP. Maybe I needed to break it in. Its still not as stiff as the Rp23. I run it on PP2 and midway compression. BoardinBob hope you are enjoying yours and again thanks for the help on buying and parts.
    The new shock is fantastic. Such an improvement. So much more controlled over rough stuff and the increased rear traction on techy climbs is a massive boost.
    local jackass
    Reputation: biggoofy1's Avatar
    can u do this on the 2010
    His
    2010 FSR XC
    2010 ALLEZ
    Hers
    2012 Myka 29'r
    2009 Cannondale Synapse 5
    Down East Cyclists
    Nov 2008
    I don't get it...I have ridden a Specialized bike with an RP23 for about a year...I just bought a 2010 FSR XC Expert with the Xfusion...and I like the Xfusion better..never did like the RP23...thats just me though....I like what I perceive as BETTER control of the shock on the Xfusion
    local jackass
    ill have to see im picking up my 2010 next month when i come back from a work event in key west lol
    His
    2010 FSR XC
    2010 ALLEZ
    Hers
    2012 Myka 29'r
    Down East Cyclists
    Bike Addiction
    X-Fusion
    Quote Originally Posted by MindTrik
    Mine was the low end version of the X-Fusion shocks. If mine had compression and dampening adjustments on it I might not have replaced. But mine only had a single red lever on it for compression I believe. When the lever was half way up the shock worked fine but it would'nt stay there. I was always reaching down to adjust. Got very annoying on tech stuff and long climbs.
    Bike Addiction
    Quote Originally Posted by biggoofy1
    Probably so.
    Quote Originally Posted by 00sable
    supposedly the trick is to tighten the bolt to stop it slackening off but not sure myself how effective it would be.
    i just turn the lever fully on for steep/big climbs or leave it off.
    I've got no real issues with mine on my 2010 comp. I suppose theres a chance that the x-fusion shocks are slightly better than in 2009.
    Quote Originally Posted by Asta
    Tighten the small allen bolt keeps the lever from slipping and yes it does work. There are then multiple settings for compression. I'm 190 lbs and I run the shock with highest compression other than lockout and the air psi is set at 140. When it it's fully open it's too pogo stick like.
    Reputation: Mr. Lynch's Avatar
    Jun 2010
    I know it's an old thread, but I thought I'd add some info.
    I recently swapped out the crappy X-fusion shock on my wife's 2010 FSRxc COmp for a 7.5x2.0 RP2. What a HUGE difference. I've rode it a few times and I think I like it better than the Triad shock on my 09 FSRxc Pro. I've had no bottom out or frame contact issues either, and this was done on a small frame.
    With the shock off the rear arms didn't contact anything until the cross tube in front of the rear tire would hit the seat post. With the RP2 completely bottomed out (with no air in it) there is still a good 1" or more or clearance. I don't think it is possible for any frame contact. I don't have any issues in the area that was circled in the picture a few posts above. I think even a 7.5x2.25 shock would clear without contact.
    Bike Addiction
    Mine still working great. Took some 2 to 3 ft flat drops too and used all the travel but no damage or frame contact. Running more air pressure now than before, around 180 psi, to get a stiffer ride but I'm always playing with air pressure. Big upgrade.
    Jun 2010
    I rode my wife's bike all weekend and the rp2 really does transform the bike. It climbs so much better with the rp2 than it ever did with the x-fusion shock. Now I need to decide if I want to keep the Triad on my XC Pro, or swap it with the rp2!
    Bike Addiction
    I still have a lot of pedalbob but locking out the front fork helps on long climbs
    Quote Originally Posted by Mr. Lynch View Post
    Did you order the same parts in the photo above for the 2010 FSRxc Comp?
    My Xfusion won't hold air and I need to rush to replace.
    2012 Niner Jet 9 RDO (Tang, XTR groupo)
    2011 Giant Reign 2 (XT groupo)
    Jun 2010
    I used the part numbers listed above. My LBS had the 803-00-119 part in stock, but I had to order the 803-03-034 from pricepoint:
    Fox Rear Shock Hardware Kits at Price Point
    I didnt need the 003-01-001a since my RP2 was used and already had then installed and they were in good shape.
    I finally want to get this done on my 2009 fsr xc. Would I be better off getting an RP2 7.25x1.75. Stock is 7.5x1.75. Or stick with RP2 7.5x2?
    Mar 2012
    low, mid or high tune?
    I'm new to all this tech talk. Can somebody explain to me the differences between low, mid and high tuned shocks? I'm planning on upgrading the rear shock on my 09 fsr to a Monarch RT3 and i've seen some good prices on mid tuned ones. Will a mid tune work for an fsr?
    Any info is appreciated, thanks!
    Where do you order these bushings? I have a 2006/7 FSR XC, so the suspension is a little different than in this thread. I tried pulling the bushings out of the stock X fusion but the ID of the shock holes is different.
    Jun 2010
    14 Aurum, 16 Fuse, 17 T130
    Doesn't have what I need at all.
    I need four flanged bushings, 12.5ish in diameter, that reduce it down to the cross bolt, which is maybe 3/8s?
    15.75mm width. 8mm bolt hold. 12.5mm diameter fox eye size.
    Anybody?
    Jun 2010
    You could try https://www.offsetbushings.com/
    They can custom make any size you need and you cna get them in offset or standard spacing. 15.7x8 is listed under the commonly ordered size chart.
    Universal cycle also has a bunch of options in that size
    https://www.universalcycles.com/shop...7&category=136
