Results 1 to 22 of 22
    Oct 2012
    Good job! Stumpynerd - Shorter Stem Debate
    This debate has probably taken place, but curious on what people are running for stem length on their stumpys and the benefits.
    I just ordered a 70mm Syntace Megaforce 2 stem to try out from my stock 90mm. My frame is an XL.
    70mm seems really short, for any bike.
    MCH Co-Captain
    Oct 2012
    Reputation: inkpad's Avatar
    I'm running a 70mm, zero rise on my Lg, 2013 Stumpy Comp HT with 780mm, 15mm rise bars. Love the way it handles! I'm 6'-1" FYI. I tried a 50mm, but it was too short for the bike IMO, & I run a 50 on my carbon Nomad trail bike.
    Just Another Ignorant 26'er
    eBiker
    Reputation: Mr.P's Avatar
    Feb 2005
    50mm on my Enduro, & 70mm on my single speed. If I could go shorter on the SS, I would. Long TT, short stem, wide bars FTW!
    P
    Oct 2012
    So far I have tried a 120mm, 100mm, and 90mm. I like the 90mm and the quicker steering response, a 70mm seems like it would be perfect for my stumpy fsr. A 50mm however might be too short, but who knows. I will eventually have an arsenal of stems to choose from!
    It would be interesting to see what length people are running on their stumpy evos?
    I ordered a 70mm to replace the 90mm on my large FSR 29er.
    JCL
    JCL is offline
    40 or 50mm depending on course on a Stumpy Evo. I think if you need more than 70mm you need a longer reach frame.
    running a 70mm Thomson with 0 rise on my 2011 SJ FSR Pro(size med)... started with a 100mm, went to 90mm and then found the 70mm to be just right and bike feels great going up and down. Also running 720mm Truvativ AKA bars and dig the wider bars.
    memento mori
    I recently went from a 90mm/650mm stem/bars to 60mm/720 on a large stumpfsr 29er. So far so good. Years back I had a medium Burner with a 23" tt, 120mm stem and 26" bars that handled great. I think the stem length and tt length can work together in different configurations with good handling traits. Extremes at either end generally don't pan out well.
    Feb 2006
    My medium evo came with a 60mm. It felt good, but I had a 50mm Thomson spare so I put that on. It feels great!
    NedwannaB
    Reputation: JMac47's Avatar
    Curious here
    Of the ones shortening up their stem/reach, how many of you are running flat bars vs risers(low riser I'm assuming, or switched to)?
    Inquiring mind(s).
    Who did he tell you that?....
    Feb 2006
    70mm / 0deg rise Thomson X4 on a 26" Stumpi Evo size L with a 740mm low rise bar.
    I´m 186cm tall.
    Oct 2012
    My large 11' SJ FSR has a 90 degree stem with a 680 low rise bar. I'm 5' 10.5" with a 31.5" inseam which is a tweener in Specie sizing.
    Threads like this have encouraged me to go with wider bars and adjust the fit with a much smaller stem.
    I'll be ordering the Havoc combo of 65mm stem and a 750mm riser bar tomorrow...and just hoping for the best I guess.
    Oct 2012
    Hey Art. C its just takes some fiddling. I have had a lot of trial and error over the years messing with stems, seatpost setbacks, and bars. See if your local bike shop will let you test out different stems and bars before ordering some bling for your bike.
    Reputation: GnarBrahWyo's Avatar
    Jun 2012
    I am looking at getting a new stem for my 2013 SJ Fsr Comp 29er (med frame) but do not know what I have. Can anyone tell me what size mine is? From what point to what point on the stem are these measured???
    Attached Thumbnails Attached Thumbnails Stumpynerd - Shorter Stem Debate-stem.jpg
    May 2005
    ^ using a metric ruler, measure from the center of the steerer tube to the middle of the handle bar. Or look on the bottom of that stem to see if it has a "60" or "70" imprinted.
    Quote Originally Posted by GnarBrahWyo View Post
    From the pic...it looks like a 70mm
    12' Sir9 Rigid
    11' Jabber Rigid
    10 SJ SS rigid
    10' Swork SS 29er
    10' Tallboy
    08' RM Vertex SS
    Jun 2012
    Thanks, guys.
    Oct 2012
    Hey Gnar, according to the Geo charts you should have a 75mm. I went from a 90 to a 70 and love it for my 2012 stumpy fsr. I picked up the Syntace Megaforce 2, this is a bad ass stem.
    Specialized Bicycle Components
    Jun 2012
    So the Syntace Megaforce 2 weighs the same as the stock stem on the new 2013 SJ 29er alloys?
    Oct 2012
    Mega Force 2 weights. Not sure on stock stem weight. Cant beat syntace 10 year warranty on their stuff, even comes with titanium bolts!
    Syntace
Hot Deals
Contests
Latest Mountain Bike Articles
