Results 1 to 6 of 6
    Mar 2005
    stumpy geometry question
    Hi All,
    i am contemplating a new stumpy frame. I am 5'8" and run 27.2" seat height (BB to top of saddle) + generally like to set up my bikes with about 1-1.5" drop to the top of the stem.
    I have done some calcs in CAD + using a -6deg stem + on a medium frame it's looking like it the front is too tall for my liking.
    is anyone able to verify this setup pls?
    thanks in advance.
    Mar 2005
    Anyone?
    Reputation: kingbozo's Avatar
    It may be. Take one for a test ride and find out.
    Mar 2005
    i guess that's the only real way of finding out - local dealer doesn't do demos. have to find somewhere else.
    I'm also 5'8", and test rode an '08 Stumpy Expert. With 2cm of spacers and a -6 degree stem, bar height was just about at saddle height. So, remove the spacers, and you're getting close.
    I'm coming from a setup with the bars lower than the saddle, and didn't expect to be very happy on the SJ, even set up as it was. Boy, was I wrong! The position is different than what I'm used to, but after less than an hour in the saddle, I was falling in love with the position and, more importantly, the bike.
    Hope this helps.
    Mar 2005
    thanks - very helpful info - i managed to get up to the shop today to do some detailed setup measurements. looks like i will get about 20mm drop with -6deg, so perfect.
    looking forward to my new frame to arrive.
