Results 1 to 10 of 10
    New question here. Stumpy FSR 120, Triad playing up- replacements?
    Hi all I recently built up a Stumpy FSR 120, nothing flash, a budget built (aka tora fork and x7). The hassle is the Triad shock.
    I have had it serviced & got all the seals done. But the toggle switch (blue) does nothing, and I'm getting about 50% sag with 260-270 psi in there (I'm a big boy 120kg).
    I'm thinkg of a replacment, I'd be grateful for the shock specs if anyone has them, and if anyone has done it, possibler replacment options.
    I have been considering the new DT shock, or maybe a Rockshox.
    29er you just know when ur ready!!!!
    Reputation: chuckie33's Avatar
    What year is the Stumpy frame? The specs are different on 08-09 vs. 07 vs. 06. I am about to replace my 07 triad with an RP23 as soon as I can find one with the right settings.
    If you ever see a turtle on a telephone pole, remember he had help getting there. Is there anything beer can't do?
    I understand that i have a 07' black FSR Stumpy 120 Pro
    From research I beliece that I have a '07 Stumpy 120 pro,
    I have attached a pic of her as currently set up.
    I'm pretty sure that's a 2005 frame. I have the same bike.
    Yep, thats an 05 Stumpy Expert I believe. Here are the specs which say that bike has a 7.5x1.75 Fox Septune.
    http://www.specialized.com/us/en/bc/...005&spid=21558
    New question here. Cheers all,
    Cool so I have an '05 with 7.5x1.75, so any ideas on a replacement shock? would love to go coil, but I know they wont fit.
    So any suggestion all?
    Big Gulps, Alright!
    Reputation: Berkley's Avatar
    It's a very non-standard size. And unfortunately, the frame design requires that the i2i and stroke remain exactly the same. You could send your Septune to Push and have it fixed...
    Axle Standards Explained
    Founder at North Atlantic Dirt, riding & writing about trails in the northeast.
    Search this forum for Stumpjumper RP23. You'll find lots of threads regarding this.
    I have an RP23 (7.5x2 modeded to 1.75) on my '06 stumpjumper.
    If an RP23 in 7.5 x 2.0" fit, I would go that route. I think the shock will fit but I can't say for sure.
    Quote Originally Posted by chuckie33
    It should fit, but you have to add a spacer to limit the travel to 1.75", otherwise the shock link will crash into the seat tube.
