Results 1 to 3 of 3
    Reputation: druidh's Avatar
    Stumpy FSR 120 Bottle Mounts
    Having the Small sized frame, I've struggled to get a bottle and cage which would fit in the available space - the Triad intrudes too much. I've eventually managed to get a side-entry bottle cage and a Spesh Little Big Mouth bottle to squeeze in.
    I'm now wanting to get a decent lighting system but the bottle-battery type look like they'll be too big. The under-frame bottle mounts look like they'd leave it too exposed.
    The bag-battery types look difficult to fit on the Stumpys frame.
    Anyone else solved this conundrum?
    druidh
    otbmbc.com
    Dec 2004
    I have a small SJ120 and I have the same problem. The bottle-type batterey I run on my Performance lights touches the dial on the septune just enough to cause me to worry.
    A friend of mine runs his bottle/battery under the frame of his enduro and has never had a problem. I'll try it on my Stumpy on Tuesday and let you know.
    Reputation: Not So Fast's Avatar
    Bottle Mount
    If you use the bottle battery be sure to tie it down. I use an old strap from a mousetrap pedal. This keeps the bottle secure "most" of the time.
