Results 1 to 6 of 6
    Feb 2005
    stumpy 120 bushing guarantee
    doe anyone know if bushings are covered under specialized 1 year guarantee on parts? some play has developed in my rear suss...tightened all the linkage bolts...no joy...the bushing are on the way out...just a question of who is gonna pay for them...
    Team Blindspot
    Reputation: S-Works's Avatar
    Quote Originally Posted by jaysus
    I'm guessing that's a wear item and not covered.
    When I need to replace mine, I get them from Fox directly. I ordered two sets, costs $18 delivered to my door. Not exactly a big ticket item.
    Astigmatic Visionary
    Mar 2005
    Quote Originally Posted by S-Works
    Where were you able to find what bushings you needed? I can't find anything on the Fox website and my shop is having a hard time tracking down someone at Fox. I have an 05 S-Works SJ and it's developed some slop where the shock eyelet connects to the linkage plate.
    Maybe JakeWake will stumble by this thread and can shed some light.
    punga!
    Team Blindspot
    Quote Originally Posted by punga
    punga!
    I called up Fox bicycle service, told them what I needed, and they sent them. They have a database for all the aluminum bushing sizes.
    Just be sure to make sure that they send you the 6mm bolt diameter for the link bush and not the 8mm bolt diameter for the frame mount. They sent 8mm front and back originally, I called them to tell them about their error, and they sent two more in the 6mm at no charge, even for shipping.
    Soft AND Tender
    Jun 2005
    Info from Fox
    You can call Fox direct at 1-800-369-7469 ext. 6550. Tell them what make and model bike you have and they will be able to send you the correct kit. I have an 05 SJ Pro 120 and the lower DU kit is what I needed. I believe this is the end that develops play the fastest.
    Faster the Better!
    Apr 2005
    bushings...
    Not covered...But real cheap 14 bucks I paid... Quick Swap...No Play...
    Eric
  1. SJ Pro 120 vs Expert 100
    By NICKP in forum Specialized
    Last Post: 12-23-2004, 07:06 AM
  2. Heckler vs. 120 Stumpy FSR Expert
    By diiulio in forum Bike and Frame discussion
    Last Post: 12-11-2004, 04:47 PM
  3. Hammerhead 3 piece link bushing question
    By HH-Xman in forum Titus
    Last Post: 06-12-2004, 08:01 PM
  4. SC Superlight vs. Stumpy FSR
    By 02Slayer in forum Women's Lounge
    Last Post: 04-26-2004, 12:50 PM
  5. Seely-re Stumpy HT 2.9 lb frames...
    By Chester in forum General Discussion
    Last Post: 03-18-2004, 12:31 PM
