The head tube angle on the Stumpjumper is pretty steep at 71 degrees. Many competing brands hardtail head tubes are 70 and 69 degrees. Adding the longer fork should raise the frame a few millimeters, slackening the angle, and may improve your handling.
I've found my 80mm travel on a Fox 80X setup a bit too twitchy, so I'm looking for a 100mm travel fork for my 2001 S-works SJ HT to smooth out the handling a little bit. It may be a few months until I have the new fork in hand, but I'll post up about it.
Someone told me that a fox 90 is really a 100 with 2 springs in it to pull it down. I don't know if it is true or not. I'm trying to figure out what fork i want to put on my frame.
I suspect the 90 fork is the same as the 100 fork. My 2003 Stumpy HT came with a Fox 80RL fork. This fork tubes and stanchions are the same as the Fox 100RL fork, except the 80mm fork has a spacer in it limiting the travel. Last time I changed my fork oil and replaced the seals, I just removed the spacer and now I have a 100mm fork. I found this info in the owners manual for the fork, which you should be able to download at the Fox Racing website.
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
