Results 1 to 12 of 12
    Dec 2016
    Stumpjumper 6Fattie w/ 3.8 Fat Tires?
    I know you're all thinking not another wheel/tire combo thread or tell me to go read the 'official' thread on this, but I've done a lot of searching and have not found my answer.
    So, for those of you who have tried to maximize the rim/tire size in your SJ6F, can any of you tell me whether a 3.8 Hodag on a 50mm rim will fit the frame and clear the chain? I just would like to know the feasibility of this as I am very much considering building this bike. I love fat biking but I also miss my full squish, so I wanted to see if it's possible to combine these two platforms for a unique build to satisfy my taste. I know there is the Bucksaw and Mutz to accomplish this, but I am a fan of Specialized and I don't know if they will ever have any FS fat bikes.
    While on the topic, what is the BB width on this bike?
    Are the frames/rear triangles the same on the 29" and 6F versions of this bike? It appears the same from the geometry chart but can someone confirm?
    Thank you!
    Jan 2017
    Did you find an answer to this? I'd like to know as well.
    Sep 2015
    I can tell you almost certainly that you will have trouble with chain clearance. Also yes as of 2017 the rear triangle on the 6fattie and 29er are the same. They were different in 2016 but it changed this year.
    Dec 2016
    Thanks McKenzie for the input. I was figuring that would be the case. Think I'll be going a different route.
    I've been running the Hodags on the stock wheels for a few months now. They measure about 3.5" at the widest nob on the stock wheels. Really like them and the floatation they provide over the rocky terrain that we have here in northern jersey. The sidewalls seem substantial enough to resist folding over even as low as 10-12psi. I rode them at 6-7 psi in fresh snow as well. Traction was great with sipes. They fit fine other than chain rub on the lowest two gears and ice packing up if i do a water crossing in freezing temps.
    Stumpjumper 6Fattie w/ 3.8 Fat Tires?-hodags.jpg
    Stumpjumper 6Fattie w/ 3.8 Fat Tires?-hodag2.jpg
    Stumpjumper 6Fattie w/ 3.8 Fat Tires?-hodag3.jpg
    Attached Thumbnails Attached Thumbnails Stumpjumper 6Fattie w/ 3.8 Fat Tires?-hodags.jpg
    Reputation: madmark's Avatar
    I would say the rear tyre would be too wide for the rear and looking at the picture above there is hardly any clearance, so you will certainly have a high risk of sawing through the stay with the tyre. With tyre flex and roll its a big risk running a 3.5 inch tyre.
    Home trails Swinley Forest UK
    Feb 2016
    i am very interested in this, could you shed more info?
    and pix with diff angles?
    thanks
    Quote Originally Posted by pescatom View Post
    Hi - The clearance is barely enough. I do have some paint removal on the inner swing arm, but nothing major. That said I did grind down the offending edge of the knob - probably a millimeter or two. Solved the issue. No rubbing at all now.
    What more do you want to know? What sort of angles?
    Feb 2016
    how bad is the chain rub in the last 2 cogs that you mentioned? thank you for this! been searching for this for a while, i just done building a '17 Stumpy, and if this works, i would be supper happy
    Stock, it's bad on the last gear, not so bad on the next one. Was also rubbing the swing arm and it did remove the paint a bit on both sides (around the size of two grains of rice side by side). I shaved the edge of the knobs with a grinder - took 10 minutes. I also swapped my chainring to a zero offset so that helps as well. Now its a lot better. No rub at all on the swingarm. Barely rubs on the second highest gear, and just a little annoying.
    Feb 2016
    gotcha, thank you!
  1. 27.5+ Stumpjumper 6Fattie
    By fc in forum 26+/27.5+/29+ Plus Bikes
    Last Post: 17 Minutes Ago, 05:34 AM
  2. 27.5+ Stumpjumper 6Fattie
    By fc in forum Specialized
    Last Post: 08-17-2017, 08:16 PM
  3. Questions about Stumpjumper 6Fattie
    By OffTheTop in forum 26+/27.5+/29+ Plus Bikes
    Last Post: 06-09-2016, 07:56 AM
  4. Replies: 2
    Last Post: 05-16-2016, 10:01 AM
  5. Stumpjumper FSR Comp 6Fattie
    By GrantM in forum 26+/27.5+/29+ Plus Bikes
    Last Post: 03-21-2016, 12:50 PM
Members who have read this thread: 9
