Results 1 to 7 of 7
    Dec 2004
    Standard Front hubs with OS28 fork.
    How does this work out? Do you loose stiffness? Does it work? I have some DT Swiss 240 hubs I want to build up and was wondering how it would work with the Specialized OS fork interface? Thanks!
    The dropouts are standard dropouts. Any normal front hub will work.
    Dec 2004
    Quote Originally Posted by Gravy Jones View Post
    So the fork is regular and the Spec. hubs flange is larger? I thought the hub and fork matched somehow?
    Nope, the forks (weather Fox or Rock Shox) are standard dropout forks. The "OS28" magic is in the axle and end caps of the hub.
    Dec 2004
    Thanks! Anyone know if the OS flange cap works on the 240 hub?
    Aug 2010
    Quote Originally Posted by mgsuarez View Post
    THey may or may not since they are a DT related product.
    However, you can buy all different end caps for the 240s. STANS sells them all on their site. If you want the same stiffness and be able to use the nice DT Swiss 9mm RWS skewer your Spesh came with up front you can buy them for $25 bucks. Honestly I can't really tell a whole bunch of difference in the 9mm thru and the 15mm thru on a bike with 120mm of suspension or less. When you start getting into 140mm plus you can tell a difference IMHO.
    Here is the STANS link if you want to grab them. I'm not affiliated with Stans. I use their products and I find their site convenient to order various hub parts since they stock them all.
    DT 240s 9mm RWS Caps for 6 Bolt
    Enjoy!
    Dec 2004
    Quote Originally Posted by TJM0031 View Post
    Enjoy!
    Thanks! Anyone know if Specialized sells the end caps separate?
  1. OS 28 front hub / standard fork compatibility?
    By el-cid in forum Specialized
    Last Post: 08-22-2011, 04:09 AM
  2. Question about converting hubs and Spec's OS28 end caps...
    By madsedan in forum Wheels and Tires
    Last Post: 06-21-2011, 05:54 PM
  3. Hub/fork compatibility for OS24/OS28/RWS?
    By Sid Nitzerglobin in forum Wheels and Tires
    Last Post: 11-18-2010, 11:42 AM
  4. Hub/fork compatibility for OS24/OS28/RWS?
    By Sid Nitzerglobin in forum Specialized
    Last Post: 11-17-2010, 07:25 PM
  5. Adapting standard front wheel to 20mm Manitou fork?
    By gopriest31 in forum General Discussion
    Last Post: 05-02-2010, 12:30 PM
