Results 1 to 26 of 26
    Specialized site down for remodeling...
    13's on the way!
    Reputation: Stumpjumper61's Avatar
    Happens about this time every year. Probably back up by Sunday
    Reputation: GTR2ebike's Avatar
    May 2010
    They normally put it down a few times before updating it. So hopefully by the end of the month.
    Yeah but its too bad that the 2013s will just be dumbed down versions of the 2012s..........
    May 2012
    Quote Originally Posted by Eyetattoo View Post
    I don't believe that...maybe at the really low end of the model ranges. but I think they've definitely made improvements to the upper end...e.g. magura breaks instead of avid, shimano xtr breaks on stumpy s-works and other tweaks.
    I like turtles
    Reputation: TiGeo's Avatar
    Why do you say that? From what I have seen, the upper end bikes are nice with some improvements such as Magura vs. Avid.
    Geologist by trade...bicycle mechanic (former) by the grace of God!
    2018 Niner RKT 9 RDO - enduro are #@$%
    Someone post a link that showed the Stumpy FSR Comp29s brakes were still Avid, but instead of the Avid7s they now show Avid5s. Could be that the info was bad...............?
    Trail Rider
    2012 Carve Pro model came with a 80mm Rockshox Recon Gold and traditional 3x10 drivetrain
    2013 Carve Comp model comes with a 100mm Rockshox Recon Gold and 2x10 drivetrain and dropped 3 lbs over the previous year due to some frame and wheel massaging. Expert models come with Rebas, and the Pros are coming with a Fox fork.
    2013 Hardrock Sport Discs come with hydraulic brakes, which are missing from the Hardrock lineup previously.
    Upper level models ditch the Avids for Maguras and lots of them include the new 1x11 setups.
    Every year, September is the month when they update their site. So the wait is officially over.
    08 Enduro: '12 Van RC2, Push DHX 5 coil, Flow EX, Hope m4, 750mm bar, Blacklite Post.
    Website
    http://all-mtn.com/
    Quote Originally Posted by SuPrBuGmAn View Post
    Do you have a link to the new specs for the Stumpy FSR Comp 29s?
    May 2012
    You were right about the stumpy comp. The brakes are avid5. The stumpy line seems to have avid 5 brakes for the most part (except for the s-works and expert).
    2013 Specialized Stumpjumper & Stumpjumper EVO | Mountain Bike Review
    Less talk, more ride...
    Here you go, straight off the dealer site.
    Stumpjumper FSR Comp 29
    Bike Geometry...
    Technical Specifications
    FRAME M5 hydroformed tubing, 29" geometry, tapered HT, PF30 BB, ISCG ’05, Command Post routing, 142mm dropouts, sealed cartridge bearing pivots, replaceable derailleur hanger, 130mm travel
    REAR SHOCK Custom FOX Float CTD Evolution with AUTOSAG, Climb, Trail, Descend settings and rebound adj., 194x48mm
    FORK FOX Float CTD Evolution 29, air spring, tapered steerer, Climb, Trail, Descend settings and reb adj., 15mm thru-axle, 130mm travel
    HEADSET 1-1/8 and 1-1/2" threadless, Campy style upper with 1-1/2" lower, cartridge bearings
    STEM Specialized XC Trail, 6061 alloy, 4-bolt, 6-degree rise, 31.8mm
    HANDLEBARS Specialized XC Mini-Riser, 7050 butted alloy, 720mm wide, 10mm rise, 10-degree backsweep, 6-degree upsweep, 31.8mm
    GRIPS Specialized Sip Grip, half-waffle aramid-infused, S/M: Regular, Others: XL thickness
    FRONT BRAKE Custom Avid Elixir 5 SL, hydraulic disc, alloy backed organic pads, HS-1 rotor. S/M: 180mm; L/XL 200mm rotor
    REAR BRAKE Custom Avid Elixir 5 SL, hydraulic disc, alloy backed organic pads, HS-1 rotor. S/M: 160mm; L/XL 180mm rotor
    BRAKE LEVERS Custom Avid Elixir 5 R SL, tool-less reach adj.
    FRONT DERAILLEUR SRAM X7, 10-speed, S3 direct mount for DMD, bottom pull
    REAR DERAILLEUR SRAM X9, 10-speed, mid cage, Type 2
    SHIFT LEVERS SRAM X7, 10-speed, aluminum trigger, w/MatchMaker clamp
    CASSETTE SRAM PG-1030, 10-speed, 11-36
    CHAIN KMC X10, nickel plate, reusable Missing Link
    CRANKSET Custom SRAM S-1250, 10-speed XC Trail double w/ alloy guard, PF30 spindle, S: 170mm, Others: 175mm
    CHAINRINGS 36/22, w/ alloy guard
    BOTTOM BRACKET SRAM PF30, OS press-in bearing, sealed cartridge
    PEDALS Resin Test Ride Pedals with toe clips, CEN std.
    RIMS Roval 29, alloy disc, 26mm wide, 32h
    FRONT HUB Specialized Hi Lo disc, sealed cartridge bearing, 15mm thru-axle, 32h
    REAR HUB New Specialized Hi Lo disc, 4x-sealed cartridge bearing, 12mm thru-axle, 32h
    SPOKES DT Industry, 2.0 stainless
    FRONT TIRE Specialized Purgatory Control, 2Bliss Ready, 60TPI, aramid bead, 29x2.3"
    REAR TIRE Specialized Ground Control, 2Bliss Ready, 60TPI, aramid bead, 29x2.3"
    INNER TUBES Ultralight presta
    SADDLE Body Geometry Henge Comp, hollow Cr-Mo rails, 143mm
    SEATPOST Specialized 2014 butted alloy, single bolt setback, 30.9mm, S/M: 350mm, Others: 400mm
    SEAT BINDER 34.9mm clamp, 7050 hard anodized alloy collar w/ QR, black
    NOTES Specialized Dangler chain management
    Specifications subject to change without notice.
    2012 Specialized Stumpjumper FSR Comp 29er
    2012 Specialized Roubaix Apex Compact
    Quote Originally Posted by Doedrums View Post
    Bike Geometry...
    How much of a down grade are the brakes going from the 7's to the 5's?
    Sent from my DROID RAZR using Tapatalk 2
    2013 Trek EX8 blue/white
    I've been wondering the same thing myself. Since the 5's are better than what I currently have I suspect it won't matter much for me.
    Quote Originally Posted by someguy4747 View Post
    True but if you could get a 2012 with 7's at a lower price due to it being last years model would be a win-win, better components and a better price.
    Not entirely true.
    This years model has the new clutch SRAM rear derailleur, it also has the new Fox CTD suspension. I guess you have to decide if those changes are worth the extra money. I have been debating that myself.
    Yeah I'm getting the 2013 Stumpjumper FSR Evo comp model(should come in today!?) All the 2012 models are sold out except for xl and I'm a medium. I didn't know about the new style derailer so that is a slight upgrade over the 2012. As for the shock the 2012 came with an rp2 so I think the CTD is also an upgrade. And like I said the Elixer 5 is a big improvement over my current brakes. I think I have the lowest level shimano hydrolic brakes. I think I have the br-m445. I have actually been happy with them though.
    Jun 2012
    2013's are up and live!
    Reputation: Devastazione's Avatar
    Dec 2009
    Quote Originally Posted by BrnHrnt View Post
    Yessss... !!
    And it won't be for long I'm afraid. Did you see the mistake already ?
    Jun 2012
    Quote Originally Posted by Devastazione View Post
    Yessss... !!
    Nope missed it. Other than some thumbnails pictures being a little wacky.
    Dec 2009
    As of tradition my market gets the worst possible color combos ever. White all the way while those few colors get mixed in a way too much mardi gras style...
    Reputation: Dirttrackin280h's Avatar
    Was the mistake the $10,000 price tag on the Enduro S-Works? Crazy!
    Yessss... !!
    May 2010
    Yessss... !!
    S-works stumpy 29 picture is of a 26
    S-works Venge Red price tag 14,000
    bog
    bog is offline
    Prices are nuts!
    Tallboy3 CC : Stigmata2 CC : Honzo carbon
    All the models aren't up yet, but most are. Want to see if they offer the EVO as frame only. The prices have officially gotten ridiculous on their upper end models.
    Their entry level models have not changed at all in the past 4 years.
    Retail on my 2008 Enduro SL comp was $3600.
    Website
    http://all-mtn.com/
    Seems like the website is fully updated. I just checked out the stumpys and I see that this section is updated. I also do not see the "early launch" section.
    Specialized Bicycle Components
