Results 1 to 5 of 5
    Specialized Enduro 29 aluminum weight???
    I posted this on 29er bikes forum too.
    Specialized only gave information regarding the S-WORKS Enduro 29er weight.
    Anybody knows the aluminum weight???
    Can't find that anywhere on the web....
    If the S-WORKS Enduro 29er weights 27.9 lbs (12.5 Kg), then how much heavier should the aluminum version be? 2-3 lbs? more than that ???
    Thanks, Mo.
    Quote Originally Posted by mo6500 View Post
    Thanks, Mo.
    Google Image Result for http://brimages.bikeboardmedia.netdna-cdn.com/wp-content/uploads/2012/07/2013-Specialized-Stumpjumper-EVO-Alloy-29er-actual-weight.jpg
    Reputation: Znarf's Avatar
    Thatīs unfortunately a Stumpjumper Evo, not an Enduro 29er. Unless I am missing something...
    ah right. with the infinite Spesh nomenclature, i gots mixed up. ok for the Enduro add 2.5 pounds....
    Didn't mean to be rude. You are right, all those slightly different products and slightly different but LONG names.
    Yay to turbo-capitalism.
    Greetings Znarf
  1. Specialized Enduro 29 aluminum weight???
    By mo6500 in forum 29er Bikes
    Last Post: 03-11-2013, 11:25 AM
  2. Replies: 5
    Last Post: 02-15-2012, 11:16 AM
  3. what is an 2011 aluminum enduro pro?
    By joyride153 in forum Specialized
    Last Post: 06-24-2011, 02:40 PM
  4. Replies: 5
    Last Post: 06-22-2011, 08:27 AM
  5. Frame weight: 2010 Enduro Expert (aluminum)
    By Dusty Bottoms in forum Specialized
    Last Post: 06-14-2011, 06:59 AM
