I have a specialized deviant and just noticed that the foam in the helmet has detached from the plastic outer shell. The helmets never taken a hit. The foam is not cracked, just separated from the shell. It has always been kept out of the heat and indoors. This seems to me to be a quality control issue. Has anyone else had this happen? It there any adhesive that I can use to reattach the foam to the shell or should I just try to contact specialized? Thanks.
