Results 1 to 3 of 3
    Specialized camber evo link - difference from stock camber?
    So - anyone know exactly what the differences are?
    I'm aware the evo link changes the geometry of the frame - lower BB height and slacker HA - but how is this different from the standard link? Is it a bit shorter?
    Have had my shock modified on a stock 110mm (48mm stroke) camber to give the 51mm stroke and 120mm travel as the camber evo - just the geometry question about the link to see if I can evo my stock camber -build kit is the same as the evo now...........
    Was thinking maybe an offset bush at the eyelet end might do the same job........
    Andy
    Bump
    I think you could be right about this. Is there sufficient clearence to do both things? Using offset shock hardware to lower the BB and slacken the HA whilst making the shock use more of it's stroke might bring the tire too close to the ST?
  1. Specialized Camber vs Camber Comp
    By moopey in forum 29er Bikes
    Last Post: 10-26-2013, 09:48 PM
  2. Advice needed. 12 Camber Comp vs 12 Camber Carbon
    By moto67e in forum 29er Bikes
    Last Post: 07-10-2012, 10:43 AM
  3. Replies: 13
    Last Post: 04-20-2012, 04:16 PM
  4. Replies: 6
    Last Post: 09-09-2011, 10:39 PM
