Results 1 to 9 of 9
    Small air compressor for tubeless tires?
    I normally am able to set the beads of a new tubeless tire with a floor pump. I often have problems if I remove a used tire and re-install it later. The beads must stretch and soften just enough that it's difficult to get them to seat.
    Does anyone know of a small and inexpensive compressor that is strong enough to pop on mountain bike tire beads?
    TOM
    USA Cycling Certified Coach
    www.tomsbicycleblog.blogspot.com
    2014 SW Epic WC
    2012 SW Epic
    2014 SW Tarmac SL4
    There's always next year.
    Reputation: padrefan1982's Avatar
    Mar 2005
    I have a small, 3 gallon Craftsmen compressor that I love. It was under 200 dollars + a cheap adopter from the LBS got me going. The model I picked up had a bunch of accessories that I use for jobs around the house (cleaning out the vacuum cleaner, etc). Worth it to me, and works like a charm on my tubeless jobs. The smaller tank means it needs to refill frequently, but I can deal with that.
    COTA member
    Reputation: Dry Side's Avatar
    My Coleman PowerMate VP201 Two Gallon Compressor has no trouble popping the beads on. Running standard tires (i.e. not tubeless ready) w/Stan's sealant on UST wheels. I do have to remove the valve cores first.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    2-3 gallons at 100psi is fine, the problem is the noise, as these types of compressors are typically super noisy. A much quieter one usually costs at least 2-3x what the cheap 2-3 gallon ones do. I used them to blow on DH tires before, no problem. Fat bike tires on the other hand, that's a whole 'nuther problem and you need a lot more air, but any normal 26 or 29er tires are fine with those small compressors.
    Pancake Air Compressor - 3 Gallon, 100 PSI
    I have had my pancake compressor from Harbor Freight for about 5 years and it works great. Inexpensive and does the job.
    Visiting St george/Hurricane? Stay at my vacation rental. Discounts for MTB's
    http://www.vrbo.com/392904
    PM me
    +1 on the Sears compressor.
    Pretty good at everything, but not really good at anything!
    Total Goober
    Same on the pancake compressor. I do it the same way Dry Side appears to. Instead of using a presta/schrader adapter, I use a regular nozzle to blow air in to the stem minus the core. Then use the small Stan's bottle to put sealant in through the stem.
    Quote Originally Posted by Fuglio View Post
    You guys suck im all bummed now
    Total Goober
    Looks like there is an okay one on ebay for $50, free shipping. Or maybe a pawn shop?
    Jan 2009
    I really like my Lezyne high volume floor pump... Never had any issues with tubeless setups... A regular pump cannot compare...
  1. What size air compressor for tubeless tires
    By jrich in forum 29er Bikes
    Last Post: 01-07-2015, 09:50 PM
  2. Tubeless/Air Compressor Newbie
    By EasyLiving in forum General Discussion
    Last Post: 10-04-2012, 03:40 PM
  3. Air Compressor for Tubeless - Minimum Specs?
    By vwvoodoo in forum Wheels and Tires
    Last Post: 10-04-2012, 12:03 PM
  4. Tubeless Compressor - Too Big?
    By naiku in forum Wheels and Tires
    Last Post: 07-29-2012, 12:17 PM
  5. Compressor necessary to convert to Stan's Tubeless?
    By jbsmith in forum Wheels and Tires
    Last Post: 07-09-2012, 07:29 PM
