Results 1 to 3 of 3
    otbmbc.com
    Dec 2004
    SJ120 FOX RL Lockout Problem
    I have a fox talas RL on an 05 stumpy.
    The lockout seems to work good only 80% of the time. Sometimes it doesn't work at all and sometimes it locks it out but not to stiff. Should I take it back to the LBS or is this normal?
    Goathead Gladiator
    Reputation: bwolmarans's Avatar
    May 2005
    max rebound damp, then min it, then cycle fork, then try again.
    Quote Originally Posted by SabbathU71
    Jan 2005
    float rl
    I had problems with my float RL fork (02) not locking out properly a few months after i got it. turns out that cause i hadn't checked the seals regularly dirt had got inside them and into the damping rod, which caused the lock out to only partially work. a full service sorted it out, might be whats happened to yours.....
