Results 1 to 5 of 5
    Aug 2005
    Bonking ... not feelin' well SJ FSR '04 Shock Link failure
    Hi!
    Has this happened to anyone?
    Was it covered by warranty? Or what happened?
    It's a '04 SJ FSR Expert Disc. I replaced bearings and bushings in October 2005. I used a torque wrench to the specified values.
    The lower eye bolt sheared right off and other bolts (and the bearings) were damaged. I actually did not notice what had happened until I washed the bike after riding.
    I'm worried that threads got damaged in the frame and/or the chainstay.
    Cheers, Hans
    Reputation: Dmytro's Avatar
    Nov 2003
    This is the first time I've read of something like this happening. Hopefully SJ will warranty your issue.
    mountain biker
    Reputation: slyfink's Avatar
    I had that happen to me on my 03 Enduro. I used to let the bushings develop more play than they should, which would lead to the bolt that goes through the linkage and the bottom shock eye breaking (I think I must have broken that bolt at least twice a year over 4 seasons). That would lead to the link being weakened, which led to what you see there.
    In summary: make sure your shock bushings are tight, and replace them often (search this forum, there's a thread on how to do that here somewhere..) That should save your bolts, and your links.
    Specialized did replace my link, but I got a used one that they must have pulled off another warrantied frame. I wasn't too rimpressed.
    Good luck with that...
    continuous growth is the strategy of a cancer cell.
    woah, scarey. Both my friend and I have bent those linkage bolts (warrantied by spec w/o problems though). I'll have to keep a close eye on it though..
    Reputation: wayneosdias's Avatar
    That seems like such an odd place for a failure. The only thing I can think of is when I redid all my bearings and put the rear triangle back together the seat stays were cocked a little to the left. I had to pull the seat stays to the center to get the link in. I mentioned this on the board and got responces that this is not uncommon. I wonder if there is some torsional load in the link somewhere?
    Ive had mine since mid 04 w/ moderate riding and have had no issues
    wayne
    89 Univega HT -???-
    92 Specd SJ HT M2 -stolen-
    92 Specd SJ HT M2 -sold-
    94 Specd SJ HT M2 -sold-
    97 Klien Mantra -sold-
    01 Specd enduro FSR
    02 Specd enduro FSR -sold-
    04 Specd stumpjumper FSR
    05 Specd enduro FSR Sworks
