Results 1 to 2 of 2
    signle speed tensioner compatiblity with P3
    hey guys, if any of you are running SS on your P series frames, what style/make tensioners are you using (chain tugs) i keep getting axle slip with my current setup! even with a 10mm solid axle! the dropout is very short, so i am having problems finding setups that work. thanks ~rj
    Meh.
    Reputation: XSL_WiLL's Avatar
    Quote Originally Posted by bighitboy
    Look into some BMX tensioners for a 3/8" axle, you may need to alter it with a dremel.
    Replace the flanged nuts with some track nuts. The track nuts will hold the wheel much more securely.
