Results 1 to 3 of 3
    Oct 2007
    Bonking ... not feelin' well Siezed chain stay bolt
    Anyone ever deal with a seized suspension bolt? The rear chain stay pivot bolt on my 2008 S-Works Stumpjumper is seized. Not only that, the bolt is now stripped! Specialized has no available stays for 2008 bikes! Tried penetrating oil, freezing bolt, eze out...
    Reputation: phlegm's Avatar
    So, we're in hardcore mode now.
    A stripped bolt extractor kit (with a little auger-type head) might be able to get enough grip to get it out. If truly seized though, a drill may be your next tool.
    Feb 2014
    Re: Siezed chain stay bolt
    Drill a relatively small hole in the center and use a extractor. Be sure to slowly thread in, they snap pretty easily if you go full speed and it really is seized because of the hardening process they use.
    If that fails, very very carefully drill it out our have a machine shop do it. Ideally, bike is in a vice with a drill press doing the work.
  1. Chain wrapping back around crank sprocket catching on chain stay what to do?
    By Thall36 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-05-2013, 08:53 PM
  2. Help! Chain will not stay on.
    By KCKS in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-29-2012, 06:09 AM
  3. Replies: 3
    Last Post: 03-04-2012, 08:40 PM
  4. Old components on new frame .2" shorter chain stay - chain length reduction?
    By DPDISXR4Ti in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-14-2011, 03:32 PM
  5. 2011 m4 pivot bearings siezed
    By Markhester39 in forum Pivot Cycles
    Last Post: 04-25-2011, 08:34 AM
