Results 1 to 5 of 5
Thread: Shorter Stem
    Shorter Stem
    I see some people are using shorter stems dan the stock ones..
    What are the Pro's / Con's of a shorter stem like the Truvatif hussefelt.
    Does is have any effect on the ride?
    my bike is an FSR XC 2007. I use it as an AM bike.. is it better to have an shorter stem for this type of riding?
    Hi :-)
    A shorter stem makes the handling faster, and puts your weight a little further back. It will enable you to raise the front wheel more easily for safe drop offs for example, and tight singletrack will be easier! So yes, within reason a shorter stem is better for AM (for the gnarly bits anyway!)
    Gareth
    Mar 2006
    Downside is that they are squirrley on the climbs. Feels like you're getting less leverage as well.
    so when climbing the front wheel tends to come up?
    I want a sorter stem for some AM riding, but also ride some xc once in a while.
    Reputation: BruisedKnee's Avatar
    righto. shorter stems -- makes the bike more responsive which is good when you are descending, but since your weight is a tad moved backwards, the climbing part becomes more tricky. you could compensate by putting your weight more forward by leaning or standing. just experiment, you could find a stem length that is just a good balance both climbing and doing down ...
