Results 1 to 3 of 3
    Reputation: jofs's Avatar
    Feb 2006
    Shimano XT hydraulic brakes on Stumpy FSR Pro 07 frame
    HI!
    I have bought a Stumpy FSR Pro 07 frame with Brain Fade and building from scratch. My problem is that the braking hose on my rear brake (Shimano XT from the 08 Shadow group set) interferes with the backmost part of the brain shock. Has anyone hade the same problem? Cannot simply find an angled nipple to avoid this problem... thus rerouting the hose immediately after the caliper.
    Hope that you understand my problem although my english may be confusing.
    Thx beforehand...
    jofs
    Edit: sorry, it's a frame from 07
    which is which, '07 or '08? anyway had the same problem with marta sl's and had a shop install a banjo end to reroute the cable
    Feb 2006
    Thanks for the answer, feel a little bit daft.. So basically I need one of these (in combination with a banjo bolt) http://www.chainreactioncycles.com/M...?modelID=20447
    jofs
