Results 1 to 5 of 5
Thread: Serial #
    Reputation: Demodude's Avatar
    Serial #
    Where is the serial # on the Demo 7? I've looked everywhere,,, the bottom bracket, chainstays, seatstays. I need to send the warranty card in.
    I'm GNARcissistic
    the #1 Stunna'
    Reputation: kawsakimx6's Avatar
    huh i would have said on the bottom of the crank.........looks like you covered that. guess i do not know
    I has Bikes
    Feb 2006
    Spec tends to print them on the bottom bracket, though I'm not sure on the Demos.
    FWIW - when I worked retail, all that was required for warranty coverage was your original receipt, just to show you've legitimately purchased the product. The warranty is entitled to the owner, it's not dependent on sending in the card. The card simply gets your name on Spec's mailing lists (and other maybe?) and you can expect some more spam in your inbox.
    Might want to clarify that though. Also, if you go through the LBS you bought the bike from for service, they'll attest to your warranty validity.
    The 2 sides of the demo 7 bottom bracket are welded together which it's probably not imprinted there like most other Spec. bikes
    I'm GNARcissistic
    UNDEAD
    Reputation: snow-man's Avatar
    too bad you don't know anybody who works at a bike shop Demodude!
