Results 1 to 6 of 6
    Mar 2005
    Septune: air chamber inverted!!!
    While preparing for a ride on a cold but sunny saturday, I notice that the rebound of the rear shock was pretty slow. I try to adjust it through the red knob but while pouching on saddle to verify, I notice that my shock was compressing, compressing and compressing without returning to it original position. I even tried to pull up the saddle while retainning the wheel on the ground but it never come back, even if I removed all the air from the shock!!!
    My mech. guys at my LBS called it an inverted air chamber shock. It didn't see that since 5 years at least. He succeeded to put it back and making it work, but it didn't last. As soon as I returned outside under cold temp (around 5C) it blowed again...
    It's under waranty, but it may take 3-4 weeks to get it back since FOX service center Canada is moving from Montreal to south shore of Montreal. Well like like the season is over
    Reputation: Not So Fast's Avatar
    That blows
    I have the septune too. I ride down to 35 degrees. How cold was it?
    Mar 2005
    Quote Originally Posted by Not So Fast
    it was around 0 to 5 C which is 32-40F. But temp should not be a problem for a shock, I have riden some others bikes with FOX, DT or Stratos shock as low as -20C (-2F)
    Reputation: mzungo's Avatar
    Sep 2004
    Quote Originally Posted by Yanick
    If theres moisture in the oil then it will be a problem. all oils get slower the colder they get.
    Reputation: Biker75's Avatar
    Yanick, you're a madman!
    Thats hardcore, bruther. Riding in that chilly weather! By that temp, I'm a couch potato, eating a bowl of chili & sipping a porter.
    JW
    Beer has food value. Food has no beer value.
    Mar 2005
    Quote Originally Posted by Biker75
    JW
