Results 1 to 2 of 2
    Septune adjustment explained?
    HI,
    I am going to pull the trigger on the FSR 120 Expert. But, I am not sure how the Septune works. There is a blue dial: which direction does it point when the shock is open (no propedal) and which direction does it point for full propedal? Also, does the dial turn in a circle and reset itself? Thanks!
    Chiho
    Reputation: plussa's Avatar
    The dial turns in a circle, resets itself and points towards the rear wheel when the propedal is off.
    The firmest setting is when you turn the dial clockwise one step from the "propedal off" position.
    It's very easy to switch from open to firmest setting while riding, you don't have to go through the other settings.
