Results 1 to 6 of 6
    Mar 2006
    Seatpost slipping
    I have a fsr stump 120 o5 s-works with a thomson post. The stock seat clamp is weak. Anybody else have a problem?
    Reputation: mcgarry's Avatar
    That came with the Specialized quick-release collar, right? You should be able to tighten that thing down as much (or more) as you could want using a 5mm hex wrench, using the hole on the side opposite the lever. Or is that not working?
    Quote Originally Posted by Blahla
    Mar 2006
    Yes
    I cranked it so hard I was worried the frame might bend.
    hmmm, then I don't know. I long ago moved away from q/r seatpost clamps on my old frame, but my new Epic came with one, so I decided to give it another chance, and have not had any problems so far.
    Reputation: Wick's Avatar
    Apr 2005
    Seatpost Slippage
    Blahla, Hope and Salsa make excellent seat clamps. Check and make sure the post or tube is not over greased. I had a post that would not sit stil on a Prophet- It turned out that it (the post) was heavily greased and wet-dried it off and re-greased and slapped a Hope QR on and never had another problem. Good Luck.
    Coincidentally, on my most recent ride I slid out in some mud and when I got up, my saddle was pointing a different direction! I suspect I may have had too much grease on the post, and I don't know my new bike well enough to know how tight it should really be; I can't say it was the collar's fault. But more importantly, my favorite baggie shorts were catching on the end of the q/r lever in some situations. Can't have that ... so, I'm going back to a non-q/r collar.
