Hello all,
I just got an used 07 stumpy, and it came with a 400mm thomson seat post.
If I lower it all the way down is possible (going down over it will hit the shock body) it still gets pretty high, so i definitly need to cut it.
My question actually is: What is the lenght you guys are using on your seatpost at the stumpy 07?
There is a sticker on the frame warning that riding with the seatpost not visible through the seat tube under hole may cause structural problems to the frame.
Is it so?
Cheers!!
