    Oct 2012
    New question here. Scratched Fork Sanction
    After getting back from a muddy ride, I noticed that my right fork sanction has a long scratch down the front. I looked a bit on the forum and people recommendations for repairs are all over the place. There is no oil leakage around the seal so I don't think I should worry about fixing it. I only feel a slight bur in one area, and not sure if its worth sanding down with fine grit sandpaper and doing more damage.
    Any thoughts?
    May 2005
    recommend using wet 1200~2000 grit sandpaper, with a light touch, to reduce the sharpness of the burr, there by keeping the seal intact.
    Reputation: GR1822's Avatar
    0000 steel wool works too. Unroll a piece, hold both short ends, and use it like you are shinning a shoe; across the stanchion, not up and down
    Oct 2012
    Thanks for your comments, I ended up using wet 1500 grit sandpaper to take out the burr. I was extremely careful and it worked just fine.
  1. Bike shop gouged / scratched my carbon fork tube
    By DustOff in forum 29er Bikes
    Last Post: 03-23-2013, 11:38 PM
  2. scratched fork air spring- is there hope?
    By mack_turtle in forum Shocks and Suspension
    Last Post: 12-13-2012, 08:03 AM
  3. 2011 Fox 32 Float 29 RLC FIT Fork sanction play
    By bassn in forum Shocks and Suspension
    Last Post: 10-12-2012, 12:34 PM
  4. Scratched Fox Fork Stanchions
    By bigzebra in forum 29er Components
    Last Post: 04-29-2012, 08:58 AM
  5. Scratched the uppers on my Fox fork, does it need replacing?
    By BeeRye86 in forum Shocks and Suspension
    Last Post: 12-20-2011, 04:14 PM
