Results 1 to 17 of 17
    dog lover-not in that way
    Reputation: 417markg's Avatar
    Nov 2007
    S-Works XX group but no MatchMaker X Clamp
    I wonder why they didn't include the SRAM MatchMaker X Clamp on the s-works epic since it has xx brakes and shifters. Seems like a no-brainer.
    http://catalog.bicycleoutfittersindy...ker-x-1124.htm
    Reputation: ia_ss157's Avatar
    The Matchmaker actually comes with the brakes or the X-Loc Hydraulic lockout (my lockout came with the shifter attachment). Since Specialized is an OEM purchaser, I imagine they bought the brakes in the least expensive format (besides those little ano red reach adjusters that I have only seen on the SWorks bikes and not any of the aftermarket brakes.)
    That is my theory at least. Saving a bit of money one set of brakes at a time (spread across a lot of brakes mind you).
    West Chester, PA
    ^ exactly. Same reason the "custom" juicy ultimates over the last couple years didn't get the proper carbon levers. Or how the "custom" xt760 cranks have a steel granny gear instead of alloy. Nickles and dimes, nickles and dimes...
    FYI, the xx match makers actually weight more then the individual clamps.
    S-Works all the bikes!
    Just another used cat for sale
    The Other Dude
    Reputation: jut8's Avatar
    Quote Originally Posted by JoshS
    Interesting, that is good to know.
    Sponsors: Specialized, Honey Stinger, The Hive, Twenty6, 661, Elka Suspension, www.Chainsmokeracing.net
    Nov 2007
    Now you tell me; I've got one on order.
    West Chester, PA
    whoa, wait a second... the matchmaker weighs more than 1 one individual clamp or weighs more than 2 individual clamps ?
    Nov 2007
    Well, my Matchmaker X clamps came in today.
    Here's a pic (the old clamps are on the left).
    I don't have a digital scale that will measure grams but in my hand they feel equal.
    West Chester, PA
    Quote Originally Posted by 417markg
    I'm glad I never bought weed from you in high school.
    hey, will someone post some pics of the xx shifter and brakes with the matchmaker? I thought about getting them, but I thought the shifter might be too close to the grip.
    Nov 2007
    Quote Originally Posted by mcmurv
    I put them on a couple hours ago. They can be installed on either side which moves the shifter position in or out (I choose in) and you have a small amount of vertical adjustment for the shifter in relation to the brake position. Here are a couple pics:
    Thanks man!
    Reputation: zippy895's Avatar
    MATCHMAKERS are 1 gram heavier .at least w/ my setup.
    xo and carbon elixer brakes. w/ matchmaker one side=18grams .w/out =17 grams.
    very miner,but why install them if weight savings is your goal.
    On my scale the right side XX Matchmaker is 26 g and the individual standard clamps it replaces are 20 g (one side only). Weight saving is not the reason you are using XX Matchmaker
    Quote Originally Posted by ErikGBL
    A more accurate scale revealed:
    Matchmaker XX: 26.05 g
    Standard XX clamps: 20.63 g
    so my conclusion above stands
    Reputation: musikfan's Avatar
    417markg,
    I have Elixir brakes that came with my Epic Marathon. How does the matchmaker clamp attach to the double bolt bracket on the brake levers, I can see easily how the shifter mounts....but it appears in your photo you have xx levers?
    thanks
    Nov 2007
    There was a slight weight penalty but it's only on one side (I am 1 x 10) and I like the simplicity.
    Here are a couple pictures of the brake side:
