Results 1 to 5 of 5
    I like turtles
    Reputation: TiGeo's Avatar
    S-Works crank w/Wolf Tooth direct mount installed!
    Ok...did a lot of reading here about the S-Works crank..seems like there were lots of issues with installation and the included BB and spindle sleeve. Not seeing what the issue was. The directions were v. clear and we (I helped the guy at the LBS do it) knocked it out fairly quick using the S-Works BB. Here are the particulars:
    The original 170mm SRAM S-1250 crankset w/Wolf Tooth ring (32T) and SRAM PF30 BB weighed 780g. New 170mm S-Works crank and BB weighed almost exactly 1/2 pound less so by my calcs, 554g w/ a Wolf Tooth direct-mount 32t ring (didn't actually weigh the S-Works gear as the shop didn't have a scale so I had to weigh my complete bike at home and I had a "before" weight). The crank spins nicely...maybe a bit tighter than the SRAM but it will loosen up with use. I used the spacer made of the double b/c Wolf Tooth says the direct-mount ring is the same width as a S-Works double spider. Its v. easy to take out/re-install (we had to do it once b/c we forgot a piece).
    Will ride in a few days when our trails dry out (rained like hell today)...hopefully will be creak free. I also need to pick up some of those rubber end-caps so I don't damage if I smack my crank arm.
    Attached Thumbnails Attached Thumbnails S-Works crank w/Wolf Tooth direct mount installed!-1544520_10151897774646723_759495451_n.jpg
    Geologist by trade...bicycle mechanic (former) by the grace of God!
    2018 Niner RKT 9 RDO - enduro are #@$%
    Feb 2013
    Looks great!
    Less talk, more ride...
    Nice job. The end caps are a must! They have saved my crank on more than one occasion.
    2018 YT Jeffsy CF Pro 29
    2012 Specialized Stumpjumper FSR Comp 29er
    2012 Specialized Roubaix Apex Compact
    Oct 2010
    You'll love it! I have it on two of my bikes. 14 S-Works Enduro and a 13 SJ HT carbon comp. I've used the Specialized BB, the Sram BB and I just installed the Wheels Manufacturing angular contact bearing BB. All work fine. Right now I am trying to decide whether to use this on my 14 SJ Carbon SS or try something new with the Raceface Next SL. Either way I'm sure it will be a nice set up.
    old fart
    +1 for the Wheels Manufacturing angular contact bearing BB. 500kms with not a sound from my SW crank.
  1. 1x S works Wolf Tooth Components chainring
    By WolfTooth in forum Specialized
    Last Post: 04-02-2014, 11:04 AM
  2. Replies: 29
    Last Post: 03-10-2014, 09:28 AM
  3. Replies: 10
    Last Post: 02-03-2014, 05:20 PM
  4. Replies: 2
    Last Post: 12-18-2013, 05:01 AM
  5. 22 tooth chainring on S-Works crank?
    By jmcdev1 in forum Specialized
    Last Post: 11-20-2011, 12:05 AM
