    I like turtles
    Reputation: TiGeo's Avatar
    S-Works crank question
    Do you have to use the BB that comes with it or will it work with a standard SRAM PF30?
    Geologist by trade...bicycle mechanic (former) by the grace of God!
    2018 Niner RKT 9 RDO - enduro are #@$%
    Nov 2006
    PF30 is PF30. It's a standard. Both will work.
    old fart
    The standard SRAM PF30 will work. BTDT. However, what I have found works best is the Wheels Manufacturing PF30 alloy BB. It has "angular contact" bearings so can survive in situ with higher side loadings than the standard bearings. Plus I find the use of an alloy shell in place of the standard plastic cups beneficial.
    amd
    amd is offline
    Oct 2011
    For those of you with the new S-works crankset, is it SRAM compatible as it looks? IE: would a stages power meter arm be compatible?
  1. New S-Works MTB Crank
    By epicbiker in forum Specialized
    Last Post: 11-26-2015, 06:37 AM
  2. Specialized S-Works Crank vs Shimano XTR Crank
    By LouisVuitton in forum Specialized
    Last Post: 09-17-2013, 05:55 AM
  3. Replies: 0
    Last Post: 05-09-2013, 08:34 AM
  4. S-works crank on alu Air9
    By Dikkie in forum Niner Bikes
    Last Post: 03-12-2013, 08:13 AM
  5. S-Works carbon crank question
    By pondus343 in forum Specialized
    Last Post: 01-17-2013, 05:50 PM
