I've got a new RP23 (7.5x1.75) on order through the local Cannondale dealer.
Hope to get it within the week.
I'm just wondering if the shock will come with the correct sized bushings to bolt straight into my 2006 SJ FSR, or should I get onto the specialized dealer and order some of these in as well?
The ones on my dead Traid look in pretty good shape. Could I push these out and use them if needed?
You'll need the bushing and reducers for the FSR. The Cannondale bushings aren't even close. If your careful, you can remove the ones from the Triad. The bushings can be ordered directly from Fox.
While I pulled out the Cannondale reducers and swapped in the FSR ones, I had no issue with using the same bushings that came with the RP23. Just took a soft mallet to the reducers and they squeezed on fine inside the bushings. I wasn't aware there were differing bushing sizes. Could this be a problem for me in the future? Premature wear? I'm not noticing any play or anything.
I, like others, used the original Triad bushing and reducers. The reducers pulled out fairly easily but the bushing was a different story. I used a highlighter, screws, bolts, a mallet, a wrench, a large mallet, an eye bolt, and washers to remove the bushing and it was not easy. I was too excited about the RP23 and didn't want to wait on new reducers and bushing.
Mine came with Cannondale reducers in the top of the shock for sure. I think there was reducers in the rear of the shock as well but the mech pulled them out before I could see it.
Hmmm... well I'm pretty sure that all the DU bushings are the same, it's the reducers that vary.
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
