Results 1 to 3 of 3
    Rovel Traverse Carbon 29 142 hub question
    I picked up a set of rovel traverse carbon 29 142 rear wheel set. The rear hub body is the one for the SRAM 1x11 I would like to swap to the standard hub body to run xt. My lbs was lost when I talked to them about this. Any chance you guys would know where I could
    Get the correct hub body? I know they are relabeled dt hubs so the parts have to be readily available if I can find where to source them.
    Any input?
    Reputation: phlegm's Avatar
    Are those 142+? This thread from Spesh support seems to discuss the opposite situation, so hopefully it helps:
    SPECIALIZED | XX1 DT Swiss freehub body
    Reputation: CarManDSL's Avatar
    Quote Originally Posted by sb1616ne View Post
    Any input?
    I have the free hub body you need. I sent you a PM.
    17 990 Element BC Ed - 25.5 lb burly
    15 Enduro Expert 29, SW build - 27.6
    14 SW Epic WC - 21.8
    12 Niner Air9RDO -16.4
  1. Syntace W35 or Roval Traverse carbon
    By allmountainbarry in forum Wheels and Tires
    Last Post: 02-20-2014, 02:07 PM
  2. Replies: 5
    Last Post: 09-22-2013, 01:28 PM
  3. Roval Traverse SL carbon AM wheels?
    By trenchDiggr in forum Wheels and Tires
    Last Post: 12-06-2012, 10:08 PM
  4. Roval Traverse on 2013 Spec Stumpy Evo Carbon
    By -C- in forum Specialized
    Last Post: 10-05-2012, 02:45 PM
  5. Question about Roval Traverse rear wheel
    By deoreo in forum Wheels and Tires
    Last Post: 07-31-2011, 06:02 PM
