Results 1 to 3 of 3
Thread: Roval Hub help
    Reputation: propguy's Avatar
    Roval Hub help
    I just got a set of Roval 29" wheels from a friend. I think they are 2010 or 11's. They're off an Epic that has the carbon front triangle and alloy rear triangle. I want to convert the 12x142 rear to standard 9 or 10x135 quick release. Can this be done with this hub? I know some of the Roval hubs are in-house shells with DT Swiss internals. I don't think this one is since it has a steel free hub.
    Can't be converted, but I would also say these look like 2013 wheels.
    S-Works Venge
    S-Works Allez
    S-Works Crux Disc
    Stumpjumper Expert EVO HT 29er
    Crux - Team Stumpjumper
    Roval Hub help
    You're probably right. I found out yesterday that the hub is a Formula. An OEM supplier like Formula probably does not have many if any hub options. The LBS is checking into it. Thanks
  1. Replies: 5
    Last Post: 01-04-2015, 07:36 AM
  2. Roval Spoke
    By Alexgonzalezmi in forum Specialized
    Last Post: 04-20-2012, 01:53 PM
  3. Roval Control Trail 29 versus Roval 29
    By protobiont in forum Specialized
    Last Post: 11-29-2011, 03:22 PM
  4. Broke Roval E5, replace with roval or stans Crest?
    By crimecrusher in forum Wheels and Tires
    Last Post: 06-27-2011, 05:59 PM
  5. roval traverse al
    By jeffn5 in forum Clydesdales/Tall Riders
    Last Post: 06-04-2011, 05:10 PM
