Results 1 to 7 of 7
    Mar 2012
    Rode epic wc, tallboy c and scalpel
    The epic simply blew the others out of the water. I went into it wanting tho tallboy for more comfort for long endurance races but it wasn't to be. The tallboy felt big and heavy and the scalpel felt sort of fragile or buzy.
    The epic felt solid smooth and incredible. Definitely the sports car of the bunch but I found the ride to be smooth.
    The epic expert carbon World Cup in black is gorgeous. I have seen some pics posted of the black on red and they do not do it justice. I am leaning towards the normal expert for more comfort. I am undecided as to 10x2 or 1x11.
    Epic Flash Boris F65X + road bikes
    Reputation: DonH's Avatar
    Sep 2004
    I'm thinking of getting a new Epic also. I love the gloss red color on the Expert, but may go with the World Cup model because I want the supposedly quicker handling and the 1 X 11.
    Decisions,decisions........
    Reputation: Biking Brazilian's Avatar
    Quote Originally Posted by donn12 View Post
    If you're looking at a WC, you can't make it the former. Unless you're strictly referring to the "normal Expert."
    So then you decided to start a circle-jerk in the Specialized forum?
    amd
    amd is offline
    Oct 2011
    dude, 1x11 is really really great. i haven't talked to anyone who regrets the switch. unless you ride your mtb on the road a lot, its perfect.
    It's all about the Epic WC. A 21lb fire-breathing XC monster.
    18 Focus Raven Max
    17 Focus o1e
    17 Yeti ASR-cT
    16 Bianchi Specialissima
    15 Echo Big Deal
    Dec 2010
    I would be careful Donn12. I retrofitted the whole XX1 Grupo to my 2012 Sworks epic size large and found that I had to go with the smallest 28 tooth chain ring. That fit my crank, but you must make sure it would fit if you need it.
    It is still geared a bit higher than I prefer. My old set up had replaced the 24t small chainring for a 22 tooth from my old pivot Mach 5. It lined up and fit perfectly. I was quite happy with that. We have very steep, long climbs, so I wish I had that small gear back again. If you're strong rider you may not need it. Best to try it out on your terrain first if possible.
    If I had to do it all over again, I still would do it since I love the simplicity of this set up, and dumps a significant amount of weight from your bike.
  1. Tallboy al vs Tallboy Carbon vs Jet9 vs epic comp
    By SaxMan2001 in forum 29er Bikes
    Last Post: 08-14-2012, 08:41 PM
  2. So I rode a SC Tallboy LT carbon.....big mistake.
    By VTSession in forum 29er Bikes
    Last Post: 06-14-2012, 05:26 PM
  3. for those in PNW that rode in the NW Epic Series Stottlemeyer
    By olyvtx in forum Endurance XC Racing
    Last Post: 05-21-2012, 06:26 PM
  4. Rode a Tallboy for the first time today.....WOW
    By nevermiss in forum Santa Cruz
    Last Post: 12-13-2011, 02:44 PM
  5. Rode a Tallboy for the first time
    By kbell in forum 29er Bikes
    Last Post: 05-13-2011, 08:51 AM
