Results 1 to 12 of 12
    Reputation: D Boogie C's Avatar
    Aug 2013
    Rockhopper build
    Parts list so far.
    -2013 RS Reba RLT SA Pushloc 120mm fork
    -Charge Spoon seat
    -Niner yawyd headset cap
    -2.4 continental mountain king II ProtTection black chili
    -Shimano M540 SPD Pedals
    -Oury lock on grips
    -Avid speed dial 7 brake levers
    -Thomson seatpost clamp
    -Easton Ec70 Xc Carbon Riser Bars 685mm
    1x9 setup
    -Sram X.9 shifter
    -Sram PG 970 cassette 11-34
    -Wolftooth components 32t
    Rockhopper XC/AM build-20131012_110923.jpg
    Rockhopper XC/AM build-20131013_141441.jpg
    Rockhopper XC/AM build-20131010_094226.jpg
    Rockhopper XC/AM build-20131010_094249.jpg
    Rockhopper XC/AM build-20130929_154733.jpg
    Rockhopper XC/AM build-20130925_161554.jpg
    Rockhopper XC/AM build-20130915_174457.jpg
    Great build so far! How do you like the Trail Kings? I was thinking about picking up a pair of them. The Rockhopper is a great bike to build up! I have a 2010 model with a lot of upgrades.
    - RockShox SID RLT Ti, Dual Air, 120mm Travel, 15mm Thru-Axle
    - Mavic CrossRide Wheelset
    - Specialized Purgatory Control 2.3" Front Tire
    - Specialized Ground Control 2.3" Rear Tire
    - Specialized Elixir 3R Brakes, 180mm Front Rotor, 160mm Rear Rotor
    - Easton Havoc 750mm Wide Bar
    - Easton Havoc 50mm Long Stem
    - Specialized SIP Grips
    - Shimano SLX 9 Speed Crankset, 22T-36T-Bash
    - Shimano PD-M520 Pedals
    - Thomson Elite Seatpost
    - Thomson Bolt-On Seatpost Clamp
    - Specialized Henge Expert Saddle
    Looking into upgrading to a 2x10 or 1x11 drivetrain in the next few months.
    Aug 2013
    they are mountain kings and they are amazing, I would def recommend them.
    [QUOTE=
    [/QUOTE]
    mmckechnie- how do oyou like it @ 120mm travel? how does it handle going up?
    thanks.
    Quote Originally Posted by RoYLsuMmiT_Hi View Post
    thanks.
    It's amazing at descending. Plush, stiff, and confidence inspiring. Climbing, the front wheel seems to wander a bit and the front wheel can easily lift off the trail if you don't have your weight over the bar. It's not bad though. Only noticeable on really steep climbs and it can be minimized by shifting your weight over the front of the bike (as you would want to do on any bike climbing).
    Definitely worth the slight climbing penalty though. It's slackened out the HTA from 70 to about 69 degrees which feels great when the trail points down. The extra 20mm of travel is nice to have when you're plowing through a rock garden or hammering over the roots. I think 120mm is perfect if you're looking to turn your Rockhopper into more of a trail hardtail vs more of a xc hardtail (think Camber vs Epic)
    Aug 2013
    what are my options for running a tapered fork?
    Big Gulps, Alright!
    Reputation: Berkley's Avatar
    Quote Originally Posted by D Boogie C View Post
    Unfortunately, not possible on that frame. Straight 1.125" only.
    Axle Standards Explained
    Founder at North Atlantic Dirt, riding & writing about trails in the northeast.
    Aug 2013
    mmm that is disappointing haha. thanks.
    Aug 2013
    Parts list updated, rockshox and charge
    Reputation: juan_speeder's Avatar
    I'm one cool cat!
    I just put some triple clamp forks on my Specialized.
    It's All Mountain now, right?
    Scarlett Johansson loves my hummus.
    Aug 2013
    sweet cat
    Aug 2013
    new pics and parts added.
  1. Specialized Rockhopper or Rockhopper comp
    By locomonkeyz13 in forum General Discussion
    Last Post: 06-15-2013, 10:03 AM
  2. RockHopper Comp 2011 VS RockHopper 2012
    By JayClaire in forum Specialized
    Last Post: 03-02-2012, 09:31 PM
  3. 2001 Rockhopper Pro vs 2010 Rockhopper Comp 29er?
    By redpointist in forum Beginner's Corner
    Last Post: 10-21-2011, 05:11 PM
  4. 2010 Rockhopper Comp vs 2011 Rockhopper
    By FL_rider in forum Specialized
    Last Post: 08-20-2011, 01:23 PM
  5. 2010 Specialized Rockhopper Comp vs 2011 Rockhopper
    By FL_rider in forum Beginner's Corner
    Last Post: 06-28-2011, 02:38 PM
