Results 1 to 5 of 5
    Mar 2013
    New question here. Rockhopper Pro or Carve .. HELP !!!
    Hi all,
    Noob here. Looking for my first real (not off the shelf) mountain bike. I am a larger guy at 6'3 and 290lbs. I am down to two bikes in my $1300-$1600 price range. The 2013 Rockhopper Pro or spend the extra on the Carve Comp. I will be doing light to moderate trail riding and a little bit on roads. Any help or advise about these two bikes or even other bikes they may work/last better for me would be greatly appreciated. Thanks in advance....
    Feb 2013
    I was in the same boat between those two models. I picked the carve comp for the better stock wheel set and the recon air fork as I don't plan on upgrading anything for a while.
    Reputation: millertm's Avatar
    both 2X10, both bikes have same brakes, one is X7 carbon rear mid cage derailer (carve), other is SLX, fork goes to the carve. I do not see "2 Bliss" on ether spec sheet. I would buy what you can afford, if possible go for the expert, you get XT derailer and better brakes.
    2012 XXL Carve Expert
    Trail Rider
    Carve comes with Ground Controls, which are tubeless... wheels are ready for tubeless conversion too.
    Go Carve, if its in your budget.
    Carve. Now has a significantly better frame than the Rockhopper (lighter alloy), in addition to the better fork and wheels.
  1. Replies: 10
    Last Post: 04-30-2014, 11:15 AM
  2. Carve Expert 29 or Rockhopper Comp 29?
    By Taurian32 in forum 29er Bikes
    Last Post: 07-16-2013, 01:45 PM
  3. Carve 2012 pro or Carve 2013 comp
    By Smilerz in forum Specialized
    Last Post: 07-11-2012, 03:18 PM
  4. rockhopper comp 29 vs carve comp 29
    By das028 in forum 29er Bikes
    Last Post: 04-09-2012, 02:10 PM
  5. 2011 Rockhopper LTD 29 or 2012 Carve Expert 29?
    By Mr. Lynch in forum Specialized
    Last Post: 09-30-2011, 10:58 AM
