Results 1 to 7 of 7
    justwanttoride
    Reputation: specializedwhore's Avatar
    rockhopper pro '08
    i have a specialized rockhopper pro '08. is this a good bike or should i invest in something better? i have upgraded and blinged up my ride but i'd like to buy new wheels and fork! should i bother or just buy another bike...2010 epic 29er?? thanks
    Religion = Non-thinking
    Reputation: louisssss's Avatar
    if ur happy with ur bike, then stick with it!
    if u got cash to upgrade, then upgrade! lol its very simple.
    what wheels and fork do u have on it now?
    RH SL Pro
    justwanttoride
    i would say im generally happy with my bike. however, the geometry makes it easy to lift up the front wheel on climbs, hence thinking of a new cross country bike! my rear wheel (stock dtswiss 445d rim and stout hub) has been a lemon since i got it. a spoke broke after 2 rides and my local lbs charged me $30 to replace it. shortly thereafter the freehub developed play and make loud cracking noises. i got that replaced($40). the problem is that i dont want to put more money into fixing this stock rear wheel when i could be using the $ towards buying a better wheelset. the fork is a recon sl coil which i enjoy as ive never rode with suspension before! but the lockout failed and recently got it warrantied. this is the reason for wanting to upgrade. id like to get a fox air fork in the future and perhaps the new mavic crossmax xt or crank bros cobalt wheels? what im wondering is if its worth upgrading to parts that is worth more than my bike??
    justwanttoride
    stock wheels and fork
    i have a rockhopper pro, stock wheels and fork. im happy with the forks performance but not the wheels! id like to get a new wheelset for christmas! louissss...i need your advice!?!
    getting my bike ready for 2012!
    i have the same wheelset and they're holding up well with me, haven't broken any spokes or anything. but they sure are damned heavy. i can make you some wheel recommendations, just give me a budget:
    http://www.bicyclewheelwarehouse.com...&productId=155
    check these out: get the color rim + nipples that u want and get the colored PUREXCR hubs. i hear they're pretty good and light. you may want to get a second opinion since i've never used these though.
    they sure are lighter than some more expensive wheels though...
    if u want something cheaper around $200 shipped u can do the WTB Laserdiscs + XT Hubs + DT Spokes.my gf just got a set of those for her myka
    RH SL Pro
    justwanttoride
    rockhopper
    im not so concerned about weight as i am strength? i weigh over 200 lbs and my stock wheels are a joke. id like to purchase a wheelset that is strong first, light second. ive been thinking a custom build of hope pro 2's, dt 5.1, dt comp spokes. i think they will cost $500 which makes me wonder if i should just get the new crossmax st discs or the crank bors iodines! what other mods are you thinking for your ride? im looking for new ideas...
    cougarbait
    Reputation: Lambdamaster's Avatar
    Nov 2008
    should be a lot less than $500, unless the dollar is crap right now
    I would venture to guess 4.2D will hold your weight with comp spokes unless you are really hard on your rear wheel
    as for ideas.. here's my mod list so far, and weight in grams
    '09 specialized rockhopper comp disc frame 17" 1600
    '10 Recon Race soloair MoCo+poplock 1623+45
    Alligator Serration 160mm Ti-Nitride+bolts 188+30
    Avid Juicy7 653
    Bontrager XXX lite grips 18
    Cane Creek S3, carbon spacers 112
    Control-Tech RaceSL Ti/Scandium 30
    DTswiss XR 4.2D limited edition 755+879
    DTswiss Revolution 2.0/1.5/2.0, alloy nipples
    Easton Monkeylite XC carbon, OS 170
    Gorilla Tubeless+Stan's sealant +60
    Hope Pro 2 hubset
    Hope Seatpost Collar, 34.9 23
    Jagwire Hyflow Hose and fittings
    Jagwire Ripcord housings, cables
    KMC X9 SL gold 241
    Lizard Skins Chainstay Protector 17
    MRP 1.X chainguide 58
    RaceFace Evolve 175mm cranks, EXI BB 629+114
    RaceFace 34T Single ring 53
    RaceFace NextSL carbon seatpost, 30.9 204
    Schwalbe Rocket Ron 2.25 Evo 455+497
    Selle Italia SLR XC gel flow 178
    Specialized mystery stem, 75mm, OS 129
    Sram X.9 short cage+hanger 208+18
    Sram PC 980, 11-34T 301
    Sram x.5 trigger shifter 186
    09AS-Rsl/09Six
