    Nov 2007
    Rock Shox Tora 305 "Le Femme" Fork
    What is different inside the Tora 305 "Le Femme" on the Myka Comp compared to the normal Tora 305/302? Is there just a softer spring inside or what?
    Also, aside from the thinner grips, 20mm shorter bars, and smaller disc rotors, what else is different on the Myka from the FSRxc?
    its designed for a woman, the frame tubes are thinner on the frame. makes the ride more enjoyable when the whole package is geared towards a woman's body and wieght.
    Maybe it gets emotional and leaks oil once a month..............
    say you are a light weight rider, around 130. Would it be better to buy a womans specific fork, such as the 302 with the Le Femme spring, or get a regular 302 and buy softer springs?
