Results 1 to 2 of 2
    Rock Hopper bottom Braket Octi size ? Square Taper MM ?
    I am putting 200 mm cranks on my RH and need to change the Octilink to a SQ Taper bearing. I am Big and ride a XXL and want the pedals to be spaced out further than stock. Do I need 68 or 73MM SQ T BB for a 2011 RH 26er?
    What size width BB do I need in Square Taper to make this work good.
    Thanks for any help.
    I was told it was a 73mm but what is the widest I should use 115 mm or 118 122 ? I have problems with my feet riding on the edge of pedals will wider bearing help?
  1. Square taper Bottom bracket is it worth it?
    By worrptangl in forum Singlespeed
    Last Post: 02-28-2013, 01:46 PM
  2. Left crankarm on square taper bottom bracket
    By ZmyDust in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-29-2013, 06:16 AM
  3. Square Taper Bottom Bracket
    By Ratman in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-23-2011, 12:28 PM
  4. 100mm Square Taper Bottom Bracket
    By sryanak in forum Downhill - Freeride
    Last Post: 12-08-2011, 07:25 PM
  5. Answer BMX square taper Bottom Bracket
    By jtrops in forum Singlespeed
    Last Post: 06-10-2011, 07:18 PM
