Results 1 to 17 of 17
    Reverb with Stumpjumper Carbon Frame? Does 4mm hose exist?
    So the hole for the dropper post is 4mm and the Reverb hose is 5mm. So is every hydraulic brake hose I can find.
    Does 4mm hose exist? The hose doesn't route straight, so it is not a simple "drill the hole a bit bigger" like on the alloy frames.
    Ideas? (Yes, I am set on the reverb)
    May 2005
    With fittings, you might be able to get this to fit somehow. 4mm OD x 3.3mm ID Black 25m (Priced Per Roll) Nylon Tubing | Fastenal
    Don't thousands of people run Reverb posts with a carbon Stumpjumper frame? There must be a good solution...
    (Appreciate the poly tubing recommendation but would prefer bike brake hose if it exists)
    I dismount he shock and route it thru the shock mount on the exterior. All u need is one more external cable guide that is adhere on
    Haven't done it yet, but I think I found a good solution. I cut apart a piece of Jagwire hose today - the inner liner that holds the fluid is just a plastic tube, 4mm or less (didn't measure but it fits).
    I think I will be taking a section of hose, keeping the outer sheathing up to where it enters the frame, jamming the end of the sheathing into the frame hole for positioning, and cutting the rest of the hose down to the liner for insertion into the frame. The part from where it exits under the shock to the post head won't have protective sheathing, but I don't think it will be a problem.
    Will post after trying it out.
    May 2005
    I recommend that you do a test outside of the bike frame first, that inner liner will expand and maybe burst, without the constrictive and protective sheathing in place.
    Oct 2007
    I have the reverb stealth on my 2013 FSR evo.
    I used a 4 foot piece of shifter cable and used spray adhesive to wrap sand paper around the cable. Run the sandpaper cable thru the hole and enlarge it just a bit to get the hydraulic hose to fit.
    Quote Originally Posted by chpfly View Post
    Did you do this with the carbon m
    Did you do this with the carbon model or aluminum?
    Reputation: c-wal's Avatar
    Re: Reverb with Stumpjumper Carbon Frame? Does 4mm hose exist?
    2013 evo is carbon.
    I ended up peeling the outer plastic liner off the back half of the hose, running the inner tube covered in braided mesh through the frame, and recoating the back half of the hose using heat shrink tubing.
    Works and looks great.
    The outer liner isn't going to be a problem, pressure isn't very high in a reverb hose (the fittings on the end are nowhere near as secure as what is used on brakes).
    Reputation: J273's Avatar
    Did you find a solution to this in the end ? Are there any thinner 4mm hydraulic hoses available ? Thanks
    I never found 4mm hose. The solution I outlined above with heat shrink works great.
    On my Stumpy Carbon, all you need to do is CAREFULLY drill the hole to 4mm.....and then install the reverb as normal..
    Quote Originally Posted by kroe View Post
    Can i ask what hose did you use?
    Quote Originally Posted by ritchief View Post
    Yeah i was going to do this and file the opening to fit the thicker hose - Not sure i fancy doing it though on a new frame.
    I used the stock reverb hose, just cut the casing off the back half with a razor blade.
    Ahh ok thankyou - I might give it a go.
  1. Replies: 38
    Last Post: 03-04-2017, 12:00 AM
  2. Replies: 1
    Last Post: 08-13-2012, 04:05 PM
  3. Replies: 11
    Last Post: 03-27-2012, 12:33 PM
  4. Replies: 2
    Last Post: 08-17-2011, 04:58 PM
  5. Replies: 1
    Last Post: 08-16-2011, 06:29 AM
