Results 1 to 5 of 5
    Reputation: bgfthntr's Avatar
    replacement / upgrade for OE X-Fusion shock
    I need to replace my rear shock and need some suggestions. The stock size is speshy specific 7.5 x 1.75. Currently the stock shock is a X-Fusion RLa. I haven't been able to find anything in that size. The closest is 7.5 x 2.0. Any suggestions.
    09 FSR XC-Comp
    thx
    Help!
    Quote Originally Posted by bgfthntr
    09 FSR XC-Comp
    thx
    Well, you can get the 7.5 x 2.0 shock and make a spacer and trim down the travel to 1.75 .I do alot of making shocks longer and or shorter.
    Or I believe you could have the company that you are getting the shock from space it down for you .
    It requires a dissembly to install the spacer --------I spin the spacers up out of aluminum .
    You know its funny ----but alot of times I get shocks that are supposed to be a certin amount of travel ------and they seem to always alittle short ---------.
    I sent an email to X-Fusion and they do OE upgrades.
    There you go ----get just what you need
